#103325 - 13/09/07 07:30 PM
Re: Stripes Question
[Re: JJST]
i think using masking tape to get your skills at getting it level would be a good start if you know what i mean
#103332 - 14/09/07 10:49 AM
[Re: Anthony1664]
Loc: West Midlands
With the help of a friend just for help with lining up the stripe. 1. at each end of the stripe stick a small lentgh of masking tape horizontaly, just enough to hold the stripe in position, now with the help of the friend look at the stripe and unstick the end (s) to get it straight and stick the ends back down. 2. when you are happy the stripe is straight were you want it apply a lentgh of tape along the top edge of the stripe to stick the stripe down along the top. 3. now remove the two end pieces of tape so that the stripe is hanging from the top tape. 4. when you are happy with the alignment of the stripe, carefully turn the stripe upwards folding it against the tape, you are now viewing the backing paper, carefully start to remove the backing paper bit by bit and allow the sripe to fold back down and stick to the car, smoothing out the stripe as you proceed to carefully remove the backing paper until finished and the stripe is on the car, check for bubbles if any and prick with a pin to the edge of the bubble not the centre, smooth over you finished stripe with a soft cloth. 5. do not wash the car for several days to allow the adhesive to bond. Hope this helps.
A Thing Of Beauty Is A Joy Forever
#103333 - 14/09/07 11:48 AM
[Re: Anthony1664]
#103337 - 14/09/07 09:04 PM
[Re: JJST]
Loc: Worcester, UK
Try DMB Graphics for all your stripe needs. www.dmb.uk.com
Gotta agree with that, Dave at DMB fitted my stripes and decals in SECONDS. VERY good job, very pleased.
#103340 - 15/09/07 10:16 AM
[Re: babyboom]
#103341 - 15/09/07 10:20 AM
[Re: JamesUK]
#103342 - 15/09/07 11:41 AM
[Re: JJST]
Loc: Rixton,Cheshire
JJST I fitted my stripes with my girlfreind so it shouldnt be hard if there is two of you bit of masking tape to adjust and a credit card and a little pin if you get very small bubbles...
Current Car: Volkswagen Golf R Mk 7 | 19 inch Pretorias | Sat Nav | Dynamic Drive Chassis | ECU Upgrade to come!
Previous Cars:Ford Focus ST2 CP320 & Ford Fiesta ST150
Car to come: Ford Mustang 5.0-litre V8 coupe in Oxford White
#103344 - 15/09/07 11:56 AM
[Re: JJST]
good luck and take your time....
#103346 - 15/09/07 01:14 PM
[Re: JJST]
Loc: West Midlands
#103349 - 15/09/07 01:51 PM
[Re: Kev]
#103351 - 15/09/07 01:59 PM
[Re: JJST]
OK.. I attempted this on my own, that was a mistake I know, I really do know now! The stickers I was sent were weird, the one was set out in such a way I could put it on in one go, the other had the 'ST' and the back bit were up the wrong end (the stickers were in two parts so you don't need to cut at the door) so I had to cut this off to do it separately, that was on the passenger side. Here's the passenger side:  There area few bumps which I'm not happy with, but from a foot away you can't notice so decided to carry on. I though the driver side sticker would be easier given that I only had to measur the correct height once, but it collapsed in the middle with too much slack and could do nothing about it - attepted to pull it back, but the sticker stretched and wa then out of shape. This is what's left of the driver side!  I am leaving the passenger one on for now, in case I can get a spare, anyway you can only look at one side at a time  Now I am kidding I will not be leaving just the one side on indefinitely, we'll see what happens!
#103352 - 15/09/07 02:00 PM
[Re: Sir Mr Fabrix]
#103354 - 15/09/07 02:12 PM
[Re: JJST]
Loc: West Midlands
The full lentgh sripe comes as one piece,you dont cut the stripe until you have finished,that way it stays straight. It depends wot set you ordered, the original as the ST at different ends each side, you can order both ST at front or at rear from DMB graphics
#103355 - 15/09/07 02:14 PM
[Re: fiestaman]
Loc: West Midlands
Phone dave at DMB he will help you out,cheaper than originals, he also fits them
#103357 - 15/09/07 04:34 PM
[Re: Anthony1664]
Loc: West Midlands
Good work thanks i hadnt got time to do all that, cheers.
#103360 - 15/09/07 05:27 PM
[Re: JJST]
Loc: Worcestershire, UK
I can supply and fit stripes for £25 A SET which should take no more than 5 minutes to fit. So straight in and straight out JOB DONE!
#103362 - 15/09/07 05:34 PM
[Re: JJST]
No problem ! Let me know if you want it done.
Cheers
#103363 - 15/09/07 05:37 PM
[Re: DMB]
the stripes look good! think u done a good job!
its a copy of a posting on STOC not my stripes........my 1st set were not straight and my second set i slipped with and streched hence i have 1 and a half sets of whitestripes in a tube waiting to go to a good home........when I get a chance I will bo off to see Dave a DMB for a nice set of sliver with red inserts
#103365 - 15/09/07 05:50 PM
[Re: JJST]
1239
