#12070 - 08/06/05 08:51 PM
Sump size
Loc: Cape Town, South Africa
I'm about to get some running-in oil (a mineral monograde such as Castrol XL), since my ST is due in two weeks time How many litres does the sump need, from drained? I guess I should order a couple of oil filters, too, while I'm at it (think I will do it myself, unless dealears get picky...)
Edited by Ryan_CapeTown (08/06/05 08:53 PM)
#12073 - 09/06/05 03:50 PM
Re: Sump size
[Re: Hugh]
OK - the reason I thought this would be the way to go is because two engine builders whom I know suggested that it is their standard practice . . . on the other hand, they deal mainly with engines for racing.
One or two "extra" standard oil changes would seem a bit safer to me, admittedly.
#12074 - 10/06/05 07:24 AM
Re: Sump size
[Re: Ryan_CT]
Loc: Pau,Girona Spain.
You can,t go wrong changing your oil after 500miles say.You could even send a sample off to be analised and you,ll know if you,ve any unusual wear,this can be done at any oil change.But it may not be necessary because my Galaxy has a magnet in the oil system which removes the metal particulates,so nothing gained.Also it is more of a problem with older engines that don,t have the same tolerances as new ones.I,d still change the oil and filter though,I did.
Aligator wrestler
#12075 - 11/06/05 09:39 AM
Re: Sump size
[Re: PeterDGM]
Loc: Warks
Wow, 500miles is a tad keen! Ryan - running in oil is used on engines like the Mini 'A' series etc.. I personally think with a monograde you'll do a lot more harm than good. Too higher grade (viscosity) you'll be blowing seals out as the pressure will be too high and too low it won't lube properly hence why multi-grade oils are specified. I personally (being a keen student of the school of running in cars) would change my oil at 1500 miles (there's no point doing it sooner as you are still running it in as components will still be bedding in) and then again after 6000miles. The thing to remember is that this is a NA 2 litre engine orignially designed for reps to cane up and down a motorway, it's not a highly tuned/stressed unit.
#12076 - 13/06/05 07:19 PM
Re: Sump size
[Re: Hugh]
Loc: deepest darkest Essex
usualy, its best to run an engine in on mineral oil then switch to f/s oil after say 2k miles! this is classed as optimum for modern engines! running f/s oil from brand new take for ever as the oil is SO GOOD that there is very little wear-which is what u want went running in! dont run really crap oil in it though!
#12077 - 13/06/05 07:20 PM
Re: Sump size
[Re: chrisb]
i mean you do want a small amount of wear which is what bedding in is!
#12078 - 23/06/05 03:08 PM
Re: Sump size
[Re: chrisb]
Loc: Warks
I understand that the running in effect afforded to you by running in using mineral oil is lost the moment you have SS or FS oil in the engine, even if you revert back to mineral oil as it leaves a film behind. That said I wonder what oil is put in the car from new? Probably semi I reckon.
To be honest I'm sure the running in of the engine is not that critical unless you intend to keep the car for the rest of your life or do 200k+ miles. Gentle driving in the earlier days pays dividends much later on, that is the issue here (incase people are wondering) but the main thing throughout a cars life is don't take the piss until the engine is up to full operating temperature (remembering that the oil takes a lot longer to warm up than the water). This and regular oil changes will see your car run a long, happy and fun life.
#12079 - 23/06/05 03:31 PM
Re: Sump size
[Re: Hugh]
Is the temp gauge in a car telling you how hot the oil is, or the water?
Cheers
#12083 - 25/06/05 07:00 PM
Re: Sump size
[Re: Ivor_Bigun]
Loc: Warks
Sorry bud, but I have got to retort to that. Please don't take this as as crticism, it's certainly not meant that way. Quote:
Modern engines are factory run in arnt they???
Most definitely not. Aston Martin, Ferrari, Porsche don't run theirs in so be sure that major manufacturers don't either. Indeed I know for a fact that they dont.
As for the magnet, the block and head are alloy (non magnetic)
An alloy can still be ferrous, depends on the 'mix' of metals (the definition of an alloy is a mixture of two or more metals). What I think you mean here though is to say they are made of Aluminium (non-ferrous). Aluminium blocks often have steel liners fitted to the bores though as a result of the poor heat and wear qualities of Aluminium, meaning there is still ferrous metal coming into contact with other ferrous metal - the piston rings. The block and the head are only the packaging though, the internals that works against each other will all be cast iron / steel (big/small ends, bearings, journals etc...) so the magnet would help ever so slightly. At the end of the day any wear would be so microscopic (not like in the old A-series days where the sump plug was magnetic and the gearbox contained in the sump so you'd get great chucks of metal appearing) that a magnet would serve no real purpose as the 'fragments' will stay caught up within the oil.
I ran the XR 2.9 4x4 on mobil 1 FS oil since then I have never bothered Just the stuff Ford put in at service time
Fully synthetic is good but if you are using the wrong viscosity oil for the engine (Mobil 1 is 0-40W) then you will do more harm than good I'm afraid. It's a common misconception that putting in any expensive synthetics is good for an engine. Ask Harry Potter on this forum about it as he has done some Dyno testing comparing Castrol GTX and Mobil 1 on an engine and the effect it had on the wear rate (bearing in mind that GTX was rated correctly). It was shocking/surprising stuff I can tell you.
#12085 - 26/06/05 09:15 AM
Re: Sump size
[Re: Ivor_Bigun]
My Escort TD did 220000KM with zero problems.And still looked as good as new.
Aligator wrestler
935
