#197496 - 04/03/10 01:31 PM Engine does not work properly
Danku Offline
Loc: Finland
I'am having a problem with my 2005 fiesta st.
I have fitted a full 4-2-1 milltek exhaust, cosworth cams, k&n.
The car worked perfecly for about 70000km but now on 87000km,
the idling of the engine is working properly but when I let revs drop from 3000rpm, revs drop too low to 500rpm and sometimes engine cuts out.
Sometimes it takes couple of tries to get it running again.
Does anyone have any ideas why is this happening?
I have checked the car does not have any
DTC.
2005 Performance Blue Fiesta ST Full 4-2-1 Milltek system, Cosworth cams, K&N 174bhp / 203Nm
#197497 - 04/03/10 01:43 PM Re: Engine does not work properly [Re: Danku]
if you have fitted cams then you seriously need to get it custom mapped.
#197498 - 04/03/10 01:45 PM Re: Engine does not work properly [Re: YellowBadge]
Danku Offline
Loc: Finland
The car had no problems for 30 000km with cams.
#197499 - 04/03/10 01:47 PM Re: Engine does not work properly [Re: Danku]
yes but the ECU has now learnt not to like them, no way the engine will be running properly, fueling will be all over the place.
#197500 - 04/03/10 02:01 PM Re: Engine does not work properly [Re: YellowBadge]
Danku Offline
Loc: Finland
but that's why the car has lambda-sensors so the ECU can calculate the correct air to fuel ratio.
#197501 - 04/03/10 03:39 PM Re: Engine does not work properly [Re: Danku]
As steve said above or check the throttle body is clean and not gummed up.
#197502 - 04/03/10 04:16 PM Re: Engine does not work properly [Re: Tez]
Danku Offline
Loc: Finland
I checked the throttle body and its clean on the outside but inside its a bit oily and black
#197503 - 04/03/10 04:20 PM Re: Engine does not work properly [Re: Danku]
Take it off the car and clean the inside of the butterfly with some carb and choke cleaner, sometimes resolves the tickover issue.
#197504 - 04/03/10 06:13 PM Re: Engine does not work properly [Re: Tez]
Seriously get a remap it would make the world of difference, cars can still run too rich or lean even if the ecu is meant to learn what the correct air to fuel ratio is
#197505 - 08/03/10 08:24 AM Re: Engine does not work properly [Re: Adam08]
Danku Offline
Loc: Finland
I cleaned the throttle body and now engine works much better. The revs no longer drop under 700rpm but now there is a new problem. Revs seem to "hang" now. For example the engine idles at 1500rpm for about 5sec and then drops to the normal 800rom.
Could this be if the butterfly valve is bit stuck?
#197506 - 08/03/10 09:19 AM Re: Engine does not work properly [Re: Danku]
I have that since I fitted my 60mm throttle body it revs high to 1,800 then gently sits perfectly on 1,000 revs.
Not sure that it's too much to worry about
#197507 - 08/03/10 10:04 AM Re: Engine does not work properly [Re: Kaxe]
Mine also does that after cleaning the TB Hope I aint damaged it
#197508 - 08/03/10 10:37 AM Re: Engine does not work properly [Re: Alex_H]
Danku Offline
Loc: Finland
Or could it be that the engine has to get used to the extra air that its getting after the clean up
#197509 - 08/03/10 03:44 PM Re: Engine does not work properly [Re: Danku]
Sounds about right...
Dave T ST?
On another note my engine light went off after the TB clean lol ...but it'll be on again soon haha
#197510 - 09/03/10 06:45 AM Re: Engine does not work properly [Re: Kaxe]
Engine revs rising and falling is normal. It's to meet emissions.
It will do it slightly more after it's been cleaned as it has to get used to the new air mix (as mentioned).
It should settle after a few 100 miles
#197511 - 09/03/10 09:42 AM Re: Engine does not work properly [Re: DAVE T ST]
Woooo! Cheers!
#197512 - 12/03/10 10:37 AM Re: Engine does not work properly [Re: Kaxe]
sandyle Offline
Loc: Cambs / Beds
I'd check your MAP sensor - I had similar problems and after that got changed everything was fine.
I wouldn't have guessed it at the time though and thought it was more to do with the remap or TB. GGR were the ones who diagnosed and sorted the issue - chaps there are far brainier than me
Moondust Silver '07 - naked - rear tinted privacy glass, Janspeed manifold, sports cat, rear box, Ramair induction kit & catcam cams. GGR 175+ custom remap. Performance magazine July 09 179bhp @ fly & 200Nm torque (before remap)
0 registered (), 5869 Guests and 0 Spiders online.
ChrisCumbria 11
ChrisCumbria 23975
