#200566 - 23/03/10 08:03 PM Reverse Gear Crunch
SilverFST Offline
Loc: Oxfordshire
When starting from cold if reverse is selected it struggles to go into gear and crashes when it does go in. If i select other gears such as 1st first then go into reverse it is fine. It seems to be that initial selection when cold. Does anyone else suffer from this and why is it caused and possible solutions?
Car is 57 place Fiesta st 17k miles and is still under warranty.
#200567 - 23/03/10 08:08 PM Re: Reverse Gear Crunch [Re: SilverFST]
They all do it, don't worry about it, nothing you can do
#200568 - 23/03/10 08:36 PM Re: Reverse Gear Crunch [Re: Adam08]
pazza Offline
Check out the handbook, it recommends you depress the clutch down for a second or so before selecting reverse.
Edited by pazza (23/03/10 08:36 PM)
#200569 - 26/03/10 04:57 PM Re: Reverse Gear Crunch [Re: pazza]
hazz Offline
Mines bad to...
Also I find you have to be at a complete standstill to get the thing in reverse, had a 'hairy' moment the other day as a bus was apporaching down a narrow street and the car wouldnt go into reverse fast enough -crunch- bad times
#200570 - 26/03/10 05:39 PM Re: Reverse Gear Crunch [Re: hazz]
Its because of the lack of a syncromesh (dont ask coz I dont know but without it you get that crunch lol) in reverse. I and a lot of other members also find putting it into 3rd and then selecting reverse helps
#200571 - 26/03/10 06:01 PM Re: Reverse Gear Crunch [Re: SilverFST]
Mortankas Offline
Loc: UK
I never tried putting into 3rd before Reverse - it works beautifully! Before that i used to depress the clutch twice, worked majority of the time but sometimes it still crunched!
#200572 - 26/03/10 06:02 PM Re: Reverse Gear Crunch [Re: PinkRinse]
Dave_P Offline
Loc: Coventry, UK
My Fiesta did it all the time, put the car in 1st gear before selecting reverse and then the input and output shafts in the gearbox will be spinning at the same speeds
#200573 - 27/03/10 08:09 AM Re: Reverse Gear Crunch [Re: Dave_P]
SilverFST Offline
Loc: Oxfordshire
Just pressing the clutch in for 5 secs now works wonders
#200574 - 27/03/10 12:57 PM Re: Reverse Gear Crunch [Re: SilverFST]
ColinO Offline
Loc: Ireland
if your moving forward, then want to go into reverse, clutch to netural, release and clutch in again and select reverse..
#200575 - 27/03/10 06:49 PM Re: Reverse Gear Crunch [Re: ColinO]
Been trying the 3rd gear then reverse since reading this post and - Success!
#200576 - 27/03/10 07:17 PM Re: Reverse Gear Crunch [Re: ST_Lee]
st_si Offline
Loc: Yeadon, Leeds
always worked wonders for me
#200577 - 01/04/10 09:54 AM Re: Reverse Gear Crunch [Re: SilverFST]
Parris Offline
Loc: Bucks
I always put it into first one or twice and then reverse, and as the others say, it works fine. I was worried when my car used to do it, but it's not an issue
08 Ford Fiesta ST- Silver Powertec SL1 Induction Kit Powerflow cat-back
#200578 - 01/04/10 03:03 PM Re: Reverse Gear Crunch [Re: Parris]
PeterST Offline
Loc: SE LDN
is anyones second gear poping out when coming down the revs to a stand still? happens quite alot to mine! still under warrenty so hopefully ford will be able to sort it...fingers crossed!!
#200579 - 01/04/10 09:24 PM Re: Reverse Gear Crunch [Re: PeterST]
mine seems to throw it out of second when i give it a boot and go to change to 3rd. only tap it and it just clunks out
#200580 - 01/04/10 09:52 PM Re: Reverse Gear Crunch [Re: H47PER]
Ford are aware of a second gear synchro problem on some ib5 boxes, from what i can gather if you drive in second gear up to about 3000 rpm and let your foot off the accelerator some jump out of gear. I could find out for definate if i see my mate whos a techy at ford.
#200581 - 01/04/10 10:01 PM Re: Reverse Gear Crunch [Re: Tez]
#200582 - 26/04/10 08:14 PM Re: Reverse Gear Crunch [Re: H47PER]
JamsportTurboSt Offline
Loc: birmingham
any info on this??
Jamsport turbo fiesta st Milltek big bore exhaust Bilstien b12 pro kit K sport 8 pot 330 breaks Stack boost gauge Stack oil gauge Stack digital lambda gauge 250 bhp 278 tourqe
#200583 - 26/04/10 08:47 PM Re: Reverse Gear Crunch [Re: JamsportTurboSt]
SparK Offline
Loc: Malta
conclusion : 3rd before reverse... works every time =)
#200584 - 26/04/10 08:52 PM Re: Reverse Gear Crunch [Re: SparK]
let the revs settle, works all the time or reverse into your parking space so you always go forward 1st
#200585 - 26/04/10 09:15 PM Re: Reverse Gear Crunch [Re: Dan_The_Man]
Bang it in with a sledgehammer
#200586 - 27/04/10 09:51 AM Re: Reverse Gear Crunch [Re: Adam08]
+1
Just to clarify and resolve any incoming lawsuits to Adam and myself, that was a joke
#200587 - 28/04/10 11:23 PM Re: Reverse Gear Crunch [Re: Alex_H]
ajwp Offline
Loc: Hertfordshire
was about to put it in reverse and heard it was about to crunch, stuck it in third and then back to reverse. couldn't believe it. sat there smiling looking like a weirdo.
#200588 - 29/04/10 12:42 AM Re: Reverse Gear Crunch [Re: PinkRinse]
CraigST Offline
Loc: Belfast
This works an absolute treat! Thanks
#200589 - 29/04/10 05:31 AM Re: Reverse Gear Crunch [Re: CraigST]
Drifter Offline
Loc: Vereeniging, South Africa
Or, just let the clutch out a little, and then re-engage. Try reverse again, wont scratch then.
#200590 - 29/04/10 03:31 PM Re: Reverse Gear Crunch [Re: Drifter]
Mine never crunches, just won't go in until I lift the clutch a little, but found the same with a couple of cars
0 registered (), 935 Guests and 0 Spiders online.
