#20768 - 27/09/05 03:48 PM Spring max Weight
DarkHayz Offline
Hi guys and gals, I emailed Apex direct to find out if my lowering springs from my old 1.4 fiesta silver would be ok to be put on my ST and they said the ST is not classed as a normal fiesta because of the 2.0ltr engine makes the car heavier. therefore they would not suggest putting the springs on! does anyone know if this is the case, or how much weight difference there is between the cars?
Fiesta Fun! Picked up Silver Phase1 28th Sept 05 Picked up Blue Phase2 1st Sept 06 and lovin the extras!
#20769 - 27/09/05 03:56 PM Re: Spring max Weight [Re: DarkHayz]
Parksey Offline
Loc: Winchester
I don't know about the actual weight difference between the two cars but I'd be inclined to only use springs which they have approved as being suitable for the ST. That said, the approved Eibach springs for the ST are the same ones that they sell for the Mk6 diesel Fiestas...
I didn't think much of the Apex springs and shocks I had on my old 206, the ride quality was bloody awful.
Official www.fordfiestast.co.uk Penguin Ball Champion 2005!
#20770 - 27/09/05 04:13 PM Re: Spring max Weight [Re: Parksey]
Al_Belly Offline
Just a quick question on the subject of springs - is the ride quality any different with Eibach springs? I really would like to drop the ST by about 30mm, although I think the ride is firm enough in standard form. I'm worried that dropping the height will make it even more harder!
#20771 - 27/09/05 04:45 PM Re: Spring max Weight [Re: Al_Belly]
MichaelST1 Offline
I wondered the same.... if it makes the ride more harsh it'll probably be a bone braker.
#20772 - 27/09/05 10:49 PM Re: Spring max Weight [Re: MichaelST1]
It is a right bone shaker. If you live somewhere with even a few pots holes, speed bumps etc then you'll notice it. I'm not getting mine done. Have been out in st_owner100's car and I just couldnt do it.
#20773 - 28/09/05 07:42 AM Re: Spring max Weight [Re: PinkRinse]
Raffe Offline
The 40 profile tyres certainly don't help the ride...I would of been happier with 16" wheels adn 45 profile tyres and a slightly lower ride height from stock...
The car as it is looks like its too tall
#20774 - 28/09/05 07:59 AM Re: Spring max Weight [Re: Raffe]
MichaelST1 Offline
Taller than normal fiestas as well!!
Odd for a sports model.... lower cetnre of gravity blah blah blah.
#20775 - 28/09/05 12:45 PM Re: Spring max Weight [Re: MichaelST1]
Parksey Offline
Loc: Winchester
I agree with Pinky, on Eibach springs alone I think the ride quality is too compromised. I've also been out in st_owner100's car (you were there too Pinky!) along one of the most rutted and bumpy roads I know in Winchester and it was a bit too much for me. I'm sure on a track the handling would be even more sublime, but I think in day to day driving it was just be too harsh. Its not to say I won't get it done though, I'd rather just wait and see what spring and damper packages become available in the near future. If you've got a properly matched spring and damper then then the loss in ride quality shouldn't be as severe.
I'm also with Raffe here, the ride of the car would be so much better had they gone with a 16" rim and a 45 profile tyre. Of course though, a 16" alloy is nowhere near big enough to satisfy the Max Power (but no common sense) generation, who this car was clearly designed with in mind...
#20776 - 28/09/05 12:48 PM Re: Spring max Weight [Re: Parksey]
Raffe Offline
Agree 100%... Was aimed at a specific market.
I actually prefer the look of the Zetec S on the 16" wheels it comes with as std..with a slight drop I think the ST would look a lot stockier adn more purposeful....obviously all IMO
#20777 - 28/09/05 01:24 PM Re: Spring max Weight [Re: Raffe]
Parksey Offline
Loc: Winchester
I'm not a fan of the style of the 16" wheel on the ZS but I agree that the ST would look far more purposeful on a smaller wheel, and I reckon the handling would be all the better for it too (see Clio 182...).
Its a shame that Ford felt the need to go with a 17" wheel just to satisfy a certain proportion of buyers, they could've at least given us the choice of wheel like you get on the continent.
#20778 - 28/09/05 01:47 PM Re: Spring max Weight [Re: Parksey]
st_owner100 Offline
Loc: Essex & Hampshire
Hello darkhayz,
Since i've been mentioned a couple of times i thought i'd better make my comment. Don't be any means fit the fiesta 1.4 springs to the ST, people have done it, and the higher front axle load (860kg versus 820kg)results in a drop of around 50mm. The Eibach springs i have fitted are approved for use on the ST and are the same springs used for the diesel fiestas (part no 10-35-010-02-22). This results in an acceptable drop of 35mm, which looks perfect and sharpens up the handling no end. However, as you've read, the ride does firm up a tad, although i wouldn't say it's as bad as Parksey and Pinkrinse may have you beleive.
171bhp BTB 4-2-1 Manifold, FIA Homologated Sport Cat, Group N Rear Section Click here for my ST Group N rally replica
#20779 - 28/09/05 04:26 PM Re: Spring max Weight [Re: st_owner100]
I guess it depends on the driver too...
#20780 - 29/09/05 08:29 AM Re: Spring max Weight [Re: PinkRinse]
SpaceCadet Offline
Loc: London
I'm with ST Owner 100 on that, have the Eibachs and of course the ride is a little bit harder, but only by say 10% or 20%. It makes the car fantastic to throw about and the main reason I did it was for the looks - it doesn’t look like an offroader now!!.
#20781 - 29/09/05 02:10 PM Re: Spring max Weight [Re: SpaceCadet]
DarkHayz Offline
Thanx for you opinions, well I think the springs are going to go up for sale on ebay or something? and I'll leave the car standard for now, but who knows might get a full kit in the future?
#20782 - 02/10/05 02:13 PM Re: Spring max Weight [Re: DarkHayz]
ST_Nut Offline
Loc: Peterborough
Ask your Ford dealer about the WOLF lowering kit. When i had my ST lowered I was offered the WOLF kit at £580 + vat (i stuck with the cheaper Eibach springs)
The kit isn't out on the market yet, but it was available through the Ford Bodyshop.
When pennies are better i'll be getting it.
On Eibach springs, the ride is most certainly firmer, but the handling of the car is increased soooo much and the lowered look, is a plus
#20783 - 03/10/05 03:06 PM Re: Spring max Weight [Re: ST_Nut]
st_owner100 Offline
£580 + vat!!! That's crazy for springs. Not to mention the fitting cost on top of that. I'm assuming this is Wolf as in 'Wolf Concept' from Germany, who make some bodykits and things for the mk6?? my Eibachs cost £290 with fitting. I'm very happy with them too
#20784 - 03/10/05 03:16 PM Re: Spring max Weight [Re: st_owner100]
Parksey Offline
Loc: Winchester
I was gonna ask whether or not that cost was for just springs or whether it was a kit which includes uprated dampers as well. Its an awful lot of money for springs only, but then hardly surprising, my Peugeot garage quoted me much the same to lower my 206.
#20785 - 06/10/05 11:17 PM Re: Spring max Weight [Re: Parksey]
ST_Nut Offline
Loc: Peterborough
The kit included the springs AND dampers. They would not sell me the springs seperately. Wolf Concept only sell them together as a kit.
0 registered (), 1958 Guests and 0 Spiders online.
