#213614 - 22/05/10 12:18 AM
Re: Air Con Not Working
[Re: House]
Loc: nottingham
ermm if it needs a regas then it wouldnt be warranty i dont think. if its lost gas and they find a leak, then it would be warranty. if its something mechanical such as pump, compressor etc faulty then it would be covered warranty. well thats how we do it at the place i work anyway lol
scotty
#213617 - 23/05/10 05:44 PM
[Re: House]
Loc: nottingham
never really looked under bonnet of ST cos not got mine yet, so dunno if its anywhere near bumper. as for cost, we charge £69 i think and thats at bmw. so i'd prob say £40 at a garage or kwikfit or somewhere like that
scotty
#213618 - 23/05/10 06:51 PM
[Re: scottyk]
scotty
Ah that's not so bad. Thought it was going to be more. Cheers
#213619 - 24/05/10 08:23 AM
[Re: House]
Mines broke and the wire to the air con was split so easy fix. Can u hear the pump kick in when u switch it on?? If not then the pump is gone or wire is cut. If the pump is going but just no cold air, you'll prob need air con recharge kit. Buy this, good stuff: - http://www.halfords.com/webapp/wcs/store...tegoryId_165632You can usually buy this stuff of ebay for half price!!
#213620 - 24/05/10 09:48 AM
[Re: thewhite1]
You should hear it click, feel through the clutch pedal, or on idle the revs will drop very slightly when it clicks When my RS is just starting up on idle it almost stalls it
#213624 - 25/05/10 02:48 PM
[Re: House]
Depends on useage, if its not used every month then it will need redoing, I have also heard generally they need redoing every 3 years
#213626 - 25/05/10 07:17 PM
[Re: House]
You can use it with heat as well you know
#213627 - 25/05/10 08:01 PM
i didnt ever know if that was true! well now i do
#213629 - 26/05/10 03:37 PM
[Re: Captain_Slow]
Just so that you can run it, also some cars have it set on as standard, remember someone moaning about it as they kept forgetting to turn it off and it was running their MPG
#213630 - 26/05/10 05:08 PM
Loc: altea spain
if the pump doesnt click it is more than likely to be lack of gas, they have pressure sensors in them so when there is no pressure it wont give a feed to the clutch to engage it the click noise you here, an easy way to find out if you have gas is take a torx scredriver ( best as it is a flat end) find the filling caps take one off then inside its a trye valve, poke the screw driver in and give it a light tap, this will let a little bit of gas out, it wont hurt your hand etc, but it will be very cold, if it isnt cold then you only have air inside. which means you need a regas.
hope this helps!
zunsport grills front and rear
yokohama parada spec 2
rear axle upgrade
k & n induction kit
4-1 milltek manifold, decat and cat back
dsc 3000 flash tune to 184 bhp
#213631 - 26/05/10 08:00 PM
[Re: harryh2410]
Loc: North Yorkshire
Ah right.
Matty
#213633 - 28/05/10 08:52 AM
[Re: House]
No thats something else, can't remember what it is now, minds gone blank
#213635 - 28/05/10 12:44 PM
what is it?
#213637 - 18/06/10 11:04 AM
[Re: House]
Guys, just spoke to Ford and seems air con recharges are covered under warranty until the first service, not after.
On this note I will be looking to recharge it myself. Anybody tell me how to do it? I have recharged other vehicles before, but I need to locate the high pressure nozzle on the Fiesta. I believe the low pressure nozzle is just on top of the front grill, but where is the high pressure side?
Thanks.
1694
