#22433 - 11/10/05 11:49 PM call me stupid
MACMAN Offline
Loc: Reigate, Surrey
well actually please dont!
but exactly when is the best time to check you oil? before you drive your car when the engine is cold or after you drive when the engine is hot?
i ask this because i drove to work this morning prob bout 20min drive got to work waited 15mins so as to let oil settle then checked my oil! it was a fair bit over the max mark on the dip stick. so now im confused do i take that as the correct reading or when its cold??????
i know silly question!!
#22434 - 12/10/05 01:32 AM Re: call me stupid [Re: MACMAN]
Jonesy Offline
Loc: west london, heathrow
when checking the oil, always check it when the engine is cold!!!
Bring It If You Think You Are Fast Enough
#22435 - 12/10/05 07:20 AM Re: call me stupid [Re: Jonesy]
ChrisSussex Offline
shouldnt you check it, after you've driven it, so it warms up and goes round the engine. then turn off, let it settle in the sump for say 15 mins, then check it? sure i read that in the manual somewhere or something
#22436 - 12/10/05 07:23 AM Re: call me stupid [Re: ChrisSussex]
MACMAN Offline
thats what i thought i did this and the oil was way above the max mark???
#22437 - 12/10/05 07:27 AM Re: call me stupid [Re: MACMAN]
ChrisSussex Offline
what after it had cooled a bit too - it does need to settle in the sump after you stop driving - maybe my 15 min stated time was a bit off - maybe a bit longer? if its over the max mark, isnt that as bad as it being under the min mark? maybe you should just pop to a local ford garage and tell them to check it. wont take them a mo?
#22438 - 12/10/05 07:30 AM Re: call me stupid [Re: ChrisSussex]
MACMAN Offline
could do that but it'd be quicker to do it myself. i think 15 mins is sufficient but im just a bit confused.
#22439 - 12/10/05 07:34 AM Re: call me stupid [Re: MACMAN]
ChrisSussex Offline
i only say that, cos if its over filled, they might need to drain some??
#22440 - 12/10/05 07:38 AM Re: call me stupid [Re: ChrisSussex]
MACMAN Offline
yeah that was my plan but i thought id check first cos some books say to check it cold some say to check it hot either way if its to much il just jack it up n take some out.
#22441 - 12/10/05 08:04 AM Re: call me stupid [Re: MACMAN]
MACMAN Offline
the story continues.... i have just checked the oil 09.00am the car has been siting there all night freezing cold and guess what the oil is above the max mark! looks like i will be letting some out 2moro! as much as i dont want to drive it i have to go to work! but that said it has done 3000 miles since i picked it up! so hopefully not to much damage has been done!
#22442 - 12/10/05 08:13 AM Re: call me stupid [Re: MACMAN]
ChrisSussex Offline
hmm yeh i reckon get some out soon as! not sure what damage it can do, but the book def said its potentially as bad as it running dry ?+
#22443 - 12/10/05 09:04 AM Re: call me stupid [Re: ChrisSussex]
PeterDGM Offline
Loc: Pau,Girona Spain.
You can put too much pressure in the oil circut,you can check the level hot or cold when hot it should read less as the oil is all around the engine.When changing do it with the oil hot,and don,t forget to fill the filter before measureing.
Aligator wrestler
#22444 - 12/10/05 10:06 AM Re: call me stupid [Re: MACMAN]
Nick02 Offline
I know this may sound like a silly question but is your driveway level? I guess if it's slightly uphill or downhill it may change the reading enought to place it above the max mark...
#22445 - 12/10/05 10:35 AM Re: call me stupid [Re: Nick02]
chrisST Offline
Loc: Gloucestershire
Funnily enough thats exactly what happened to my sister when she was checking her Fiesta Flame. It convinced her that she needed more oil so she was about to put more in, luckily I re-checked it before she did it.
Like Nick says it is possible, our driveway is only on a very slight slope.
#22446 - 12/10/05 10:35 AM Re: call me stupid [Re: Nick02]
MichaelST1 Offline
Another silly question is the dipstick clean when checking oil?
#22447 - 12/10/05 12:40 PM Re: call me stupid [Re: MichaelST1]
DarkHayz Offline
If the oil levels good there will be oil on it, if the oil levels bad! then there probably won't be. Expect to hear nasty noises soon if the second one applies
Fiesta Fun! Picked up Silver Phase1 28th Sept 05 Picked up Blue Phase2 1st Sept 06 and lovin the extras!
#22448 - 14/10/05 11:48 AM Re: call me stupid [Re: DarkHayz]
MACMAN Offline
yeah drive is level and i decided to let some out! rather than taking the nut out i decided to syphen some out of the dipstick hole! used a turkey baster and some tubing! worked rather well i thought! so oil level is now fine!
SPINING INTO 2ND? GOOD CHOICE!
0 registered (), 1572 Guests and 0 Spiders online.
