#228582 - 07/08/10 12:31 PM 3rd service and 1st m.o.t
stokest Offline
what gets done and changed on the 3 rd service and how much is cost for both service and m.o.t
#228583 - 07/08/10 12:41 PM Re: 3rd service and 1st m.o.t [Re: stokest]
Service should be about £230
The list is in a topic somewhere
#228584 - 07/08/10 12:49 PM Re: 3rd service and 1st m.o.t [Re: Adam08]
Service Schedule for third year service.
Model Fiesta 2001
Variant DURATEC-HE/MAN (01/2005 - 09/2008)
VIN
Interval 3 Years (37500 ml)
Repair/Order No
Reg. No.
Reg. Date
Radio Code
Mileage ml
Outstanding Field Service Actions. Please ensure they are completed.
No Campaign Message(s) found
Driving Vehicle into Workshop
Instrument gauges, warning/control lights and horn Check operation
Clutch Check operation/adjust, if necessary
Washers, wipers Check operation/adjust, if necessary
Inside Vehicle
Exterior and respective control lights; instrument cluster illumination Check operation/condition
Odour filter Renew
Under Hood
Spark plugs Renew
Induction air filter Renew (more often in polluted conditions)
Under Vehicle
Engine Drain oil and renew oil filter
Tyres Check wear and condition, especially at tyre wall, note tread depth RF mm, LF mm, LR mm, RR mm
Brake system With wheels on, check brake pads and discs for wear. Check rear brake drums - in case of abnormal fluid loss, a separate order is required to investigate and rectify. (More often under severe duty conditions).
Outside Vehicle
Engine Refill engine oil
Tyres Adjust pressure
Spare wheel Adjust pressure, check wear - condition (note tread depth) mm
Service reminder sticker Affix to driver side B pillar
Extended Period Maintenance
Brake system Every 2 years - Renew - brake fluid (LTS 12 154 4)
Air conditioning Every 3 years - Check temperature at the evaporator outlet tube. Check air conditioning lines for damage and leaks (LTS 34 619 1) (TSB 67/2002)
Cooling system Every 10 years - Drain, flush and refill with purple Super Plus(LTS 24 122 4)
Auxiliary drive belts Every 125 000 miles/10 years - Renew (LTS 21 567 5)
Extra Services and Additional Offers * (optional - upon customer request / charged seperately)
AC maintenance package Air Conditioning (A.C.) system check. Apply A.C. cleaner to air distribution system. (LTS 54 552 4)
Odour filter plus Upgrade odour filter to odour filter plus
#228585 - 07/08/10 01:12 PM Re: 3rd service and 1st m.o.t [Re: Tez]
Where's Dave gone, he's got the list
#228586 - 16/08/10 12:50 PM Re: 3rd service and 1st m.o.t [Re: Duncan_P]
gary4vicky Offline
my cars got it first mot on the 3rd of september. I booked it in with ford incase going somewhere else made them go funny about the extra 3 years warranty i have on it. I forgot to ask how much it was tho lol. Is it about £50 or slightly more expensive coz its ford?
Poppy:
Tinted third brake light
DMB Badges
Mountune pas cooler
Painted Calippers
hose covers
MR200
Mountune billet arm
Front Strut Brace
35mm eibachs
Mountune big brake kit
#228587 - 16/08/10 04:04 PM Re: 3rd service and 1st m.o.t [Re: gary4vicky]
The current recommended fee by the DoT is £54.85, however individual garages can charge less than this (but not more).
#228588 - 16/08/10 07:48 PM Re: 3rd service and 1st m.o.t [Re: ChrisCumbria]
gary4vicky Offline
got an e-mail saying i'm getting it for £39 as a special offer. If one of your tyres has a cut into the side wall with a chunk taken out of it is that a failiure on an mot?
Poppy:
DMB Badges
Mountune pas cooler
Painted Calippers
hose covers
MR200
Mountune billet arm
Front Strut Brace
35mm eibachs
#228589 - 16/08/10 07:57 PM Re: 3rd service and 1st m.o.t [Re: gary4vicky]
I pay £30 for an MOT, as for a cut in the sidewall of your tyre, yes it could fail an MOT test, if the tyre hits something in the road like a pothole it will put pressure on the weakest part of the tyre and could blow out.
#228590 - 16/08/10 07:58 PM Re: 3rd service and 1st m.o.t [Re: Tez]
gary4vicky Offline
do you reckon its advisable to get a new tyre or to see what they say when it goes in for it? is there anyway it can be repaired?
Poppy:
DMB Badges
Mountune pas cooler
Painted Calippers
hose covers
MR200
Mountune billet arm
Front Strut Brace
35mm eibachs
#228591 - 16/08/10 08:00 PM Re: 3rd service and 1st m.o.t [Re: gary4vicky]
you cant repair it if its near or on the sidewall, go and ask a tyre specialist if your unsure, do it before the test cos if it fails you will only have to take it back for a re test unless they do it there and then.
#228592 - 16/08/10 08:04 PM Re: 3rd service and 1st m.o.t [Re: Tez]
gary4vicky Offline
i had a thorn in one of my tyres and it was in the sidewall and the tyre place said they couldnt repair it. Think i might have to get a new tyre then. thanks for the advice. would you be able to get the p zero's from any tyre place?
Poppy:
DMB Badges
Mountune pas cooler
Painted Calippers
hose covers
MR200
Mountune billet arm
Front Strut Brace
35mm eibachs
#228593 - 16/08/10 08:05 PM Re: 3rd service and 1st m.o.t [Re: gary4vicky]
Why would you want to get hold of p zeros
#228594 - 16/08/10 08:07 PM Re: 3rd service and 1st m.o.t [Re: Adam08]
gary4vicky Offline
would it make much of a difference to the car if i had 3 p zero's on it coz the other 3 are fine and then had a different make for the one that needs replacing?
Poppy:
DMB Badges
Mountune pas cooler
Painted Calippers
hose covers
MR200
Mountune billet arm
Front Strut Brace
35mm eibachs
#228595 - 16/08/10 08:10 PM Re: 3rd service and 1st m.o.t [Re: gary4vicky]
if the others have loadsa tread left then stick a pzero back on
But if they are getting low on the opposite side then swap to something else
#228596 - 16/08/10 08:11 PM Re: 3rd service and 1st m.o.t [Re: gary4vicky]
My mums car has about 3 different makes of tyre, but she only drives at 25mph everywhere not too sure about doing it on an I wouldn't but its a pain if you dont need to buy two
#228597 - 17/08/10 12:15 PM Re: 3rd service and 1st m.o.t [Re: Alex_H]
gary4vicky Offline
the others have still got loads of tread on. It says serious cuts fail on the mot but would a gouge about 10mm by 10mm and a couple of mill deep count as a serious cut?
Poppy:
DMB Badges
Mountune pas cooler
Painted Calippers
hose covers
MR200
Mountune billet arm
Front Strut Brace
35mm eibachs
