#283099 - 24/02/11 08:46 PM DSLR Auto to manual: Shutter speed
Right, I've seen a few people post up that they are struggling with their DSLRs and are still using auto mode so I thought I'd help out and write a very simple guide to get people going in the correct direction. I'll do another two guides once people have understood this one
Firstly, I'd like to point out that I am very very far from being the expert and all of my knowledge comes from a book called 'Photography for Dummies' and a lot messing about with settings on the camera while out and about.
The book can be bought here from Amazon or just do what I did and go to the library and get one... I read this cover to cover first and then went through it using the camera at the same time.
A few term definitions first:
Focal length - Basically the amount you are zoomed in or out
Aperture - The hole that lets the light through the camera lens
SO, photography isn't about having a fancy camera. Having a little understanding about lighting and picture composition go along way. This guide will only be about the technical bits of DSLR cameras but if people would like a guide on them I'll do one once this is finished.
I think there are three main settings on the camera that you need to be aware of. These are:
-Shutter speed
-Aperture size
-ISO setting
Each of these three aspects will influence the other setting used when taking a picture. To keep things simple, I'll just focus on the shutter speed setting first.
On your camera screen the shutter speed will (generally) be displayed as 1/something. What this means is, when you press the shutter release button, the shutter in the camera moves out of the way and allows light to hit the sensor for that portion of a second. So, if your shutter speed is 1/200 light will hit the cameras' sensor for 1/200th of a second.
The only exception to this is when your shutter speed is a second or longer, it will be displayed as a whole number.
The shutter speed on my DSLR ranges from a 30 sec to 1/4000.
Something that can be found confusing is working out which setting is faster, 1/2 or 1/320. How I remember it is this: 1/2 is a much bigger portion of pie than 1/320 and is therefore a longer shutter speed, or exposure time as it is sometimes called.
As a general rule, you want the shutter speed fast enough to stop any blurring in the picture.
How this affects your picture - If your subject is still then the shutter speed wont be a major factor to consider when taking a picture, but as a general rule you want to have 1/focal length. This helps to stop hand shake occurring in your images.
You can see on this image that the focal length is set to 17mm so to stop camera shake appearing in your image you'll want 1/15 or 1/20. Some people have steadier hands than others so can get away with slower speeds.
If your subject is moving, for example when taking pictures of fast moving sports events , the shutter speed is a very important factor. You'll want it high enough to stop any movement showing.
The goose in this picture was madly flapping its wings so I set the shutter speed to a fast speed, 1/500, before I took the picture and managed to just about freeze the image.
This next image shows a poor choice of shutter speed. As you can see, the limo was driving along the road where we had parked and what I had intended to do (long story ) was make the picture look like it had stopped in front of our cars. Unfortunately my shutter speed was far too slow and the limo blurred its way across the picture
So a practical exercise for you. If you are using Canon or Nikon DSLR's then select Shutter priority mode, functions TV or S respectively. If you're using Olympus or Sony I have no idea what the setting is, refer to the manual . When using this function you can only control the shutter speed and the camera works out the other settings, perfect for seeing the affects of changing the speeds.
What I would suggest is to go and find something that is moving, like branches on a tree when it's windy and try these two settings: 1/30 and 1/400 and compare the difference in the final image. You'll probably find, providing it's windy enough, that on 1/30 the branches are all blurred but 1/400 shows that the tree is still.
Another good way of testing shutter speed is to get a friend/parent/son/daughter/random stranger to throw a ball vertically up in front of the camera. Take a picture of the ball using the two settings above and notice the difference, you may have you use a faster setting than 1/200 to completely freeze the ball in mid air. This method does take a bit of trial and error/patients though to make sure you get the ball in the frame.
Please feel free to post up any questions you have and I'll try and answer them. If you do try the practical bit, upload your images
#283100 - 24/02/11 08:48 PM Re: DSLR Auto to manual: Shutter speed [Re: Duncan_P]
yes i agree....
#283101 - 24/02/11 08:49 PM Re: DSLR Auto to manual: Shutter speed [Re: Dan_The_Man]
Good lad
#283102 - 24/02/11 08:50 PM Re: DSLR Auto to manual: Shutter speed [Re: Duncan_P]
im totally lost with cameras!
#283103 - 24/02/11 08:52 PM Re: DSLR Auto to manual: Shutter speed [Re: Dan_The_Man]
Thats why I wrote it, hopefully It will help someone
#283104 - 24/02/11 09:01 PM Re: DSLR Auto to manual: Shutter speed [Re: Duncan_P]
Brilliant Photography info write-up Duncan.
The problem you had with the limo is that you just pointed the camera at the 's and took the pic while it drove past.
Your settings were correct, but you needed to Focus on the limo coming down the road, moving with it, and get multiple shots as it goes past.
Focus is the big one... Not to good on that one myself.
#283105 - 24/02/11 09:21 PM Re: DSLR Auto to manual: Shutter speed [Re: Kev]
Cheers Kev The limo one was taken with a compact camera, it used a slow shutter speed to compensate for the low light. I had no real control with this. Only used the picture to show what happens when something blurs in a picture
#283106 - 24/02/11 09:31 PM Re: DSLR Auto to manual: Shutter speed [Re: Duncan_P]
Top effort buddy, must have taken a bit of thinking about
#283107 - 24/02/11 09:35 PM Re: DSLR Auto to manual: Shutter speed [Re: Duncan_P]
Thats a great guide Duncan
Another aspect to take into account with shutter priority is the iso number. If you are finding your pictures underexposed/dark try using a higher iso. Normal scale is 100,200,400,800,1600. This is mainly aplicable at higher shutter speeds.
If you are trying to take a picture of an object into the sun or a high contrast scene then image may underexpose. This is because the camera will try and get the perfect exposure. To overcome this you can change the Exposure Bias. On the canon hold the av +/- and turn the scroll wheel to the right. This will effectivly overexpose the image so the subject is exposed correctly.
Looking through the view finder you will see the display below. To over expose by one stop turn the wheel right so the cursor is above the 1 on the right.
400 is shutter speed
4.0 is aperature
-2..2 is your exposure meter. 0 Is what the camera thinks is the proper exposure. It will have a little line above that moves along the numbers.
100 is iso
400 4.0 -2..1..0..1..2 100
+1 Exposure Bias
Pigeon coming into land by Micky Photography, on Flickr
As you can see the pigeon is properly exposed and the sky is a bit brighter.Before the sky was darker and the pigeon underexposed.
If at anytime the aperature (4.0 in the quote above) is flashing your camera will underexpose. Either up the iso or slow down your shutter till it doesn't flash anymore or changes to a higer number.
#283108 - 24/02/11 10:13 PM Re: DSLR Auto to manual: Shutter speed [Re: Micky]
I wasn't going to go into all that yet but cheers. Saved me writing it up
#283109 - 24/02/11 10:40 PM Re: DSLR Auto to manual: Shutter speed [Re: Duncan_P]
Following the object.. Spanning, blurring the backround with wheels in motion...
#283110 - 24/02/11 11:13 PM Re: DSLR Auto to manual: Shutter speed [Re: Kev]
i thought that when writing it but thought it would come in handy. Maybe get a sticky made so we can have an index to the threads.
#283111 - 25/02/11 10:01 AM Re: DSLR Auto to manual: Shutter speed [Re: Micky]
i am lost but when i get home im going to read it a few times and ill get the camera out and see if can change the settings etc.thx for the write up it will be a big help to me
#283112 - 25/02/11 10:22 AM Re: DSLR Auto to manual: Shutter speed [Re: kenny]
Great write up Duncan, I'd like to get a DSLR one day
I bet
Me at RR day: Got used to the camera yet then?
You: Nope, I just stick it on auto
#283113 - 25/02/11 10:59 AM Re: DSLR Auto to manual: Shutter speed [Re: kenny]
It will make a lot more sense if you can have the camera handy at the same time. There is no excuse for not taking practice shots though, its not like you have to buy film any more Post up if something doesn't make sense Kenny
#283114 - 26/02/11 12:50 PM Re: DSLR Auto to manual: Shutter speed [Re: Duncan_P]
rhino Offline
Loc: grimsby
good info given through out ... if any one has any questions about photography feel free to pm me im no expert but been doin it for quite a while and always like to help here are a few examples of what i have done
if any of you love power and get chance to go to wales at the mach loop you will love this 150ft low directly past you at 600mph what a experiance
if theres a problem with these being on here just pm me thanks
#283115 - 26/02/11 01:35 PM Re: DSLR Auto to manual: Shutter speed [Re: rhino]
matt22 Offline
wow those pics of the planes are amazing! well done!
#283116 - 26/02/11 01:44 PM Re: DSLR Auto to manual: Shutter speed [Re: matt22]
rhino Offline
Loc: grimsby
thanks mate
#283117 - 26/02/11 01:49 PM Re: DSLR Auto to manual: Shutter speed [Re: rhino]
LozzyST Offline
Loc: Wigan, Lancashire
Wow they are brilliant
[color:"magenta"]TEAM STOZZY FTW[/color]
FE<img src="/images/graemlins/stemo.gif" alt="" />Y
Milltek 4-1 Evo Manifold, Sports Cat and Cat back <img src="/images/graemlins/smile.gif" alt="" />
K&N 57i
60mm throttle body
Magnecor Leads
#283118 - 26/02/11 01:49 PM Re: DSLR Auto to manual: Shutter speed [Re: rhino]
Nice photos
Need to practice with mine some more
#283119 - 26/02/11 02:38 PM Re: DSLR Auto to manual: Shutter speed [Re: Adam08]
rhino Offline
Loc: grimsby
thanks guys got loads more if ppl are intreasted
#283120 - 26/02/11 02:47 PM Re: DSLR Auto to manual: Shutter speed [Re: rhino]
matt22 Offline
yeh start up a topic mate
#283121 - 26/02/11 03:20 PM Re: DSLR Auto to manual: Shutter speed [Re: matt22]
rhino Offline
Loc: grimsby
will do
#283122 - 26/02/11 03:41 PM Re: DSLR Auto to manual: Shutter speed [Re: rhino]
Great pics would love to see more!
Some nice glass aswell i'm guessing if your managing f3.2 @300mm
#283123 - 26/02/11 04:13 PM Re: DSLR Auto to manual: Shutter speed [Re: Micky]
rhino Offline
Loc: grimsby
thanks peps ... micky if ya mean the f-16 shot i was using nikon 300mm f.2.8 prime
.. jut posted a few ive done in a seperate post
0 registered (), 3517 Guests and 0 Spiders online.
ChrisCumbria 2
ChrisCumbria 23966
