#451015 - 17/07/12 04:45 PM
Engine torque link
Hi guys, A recent healthcheck on my car by Ford threw up that the engine/gearbox torque converter link has a slight tear in the bush. Its not a massive tear but it could signal problems later on down the line. I was thinking, while it was out, to polybush it, or get an uprated item (with the intentions further down the line of polybushing everything). Where can I get the polybushes for the torque link, or how much are replacement items? What's the general feeling about them? Alex, I know you have one, do you notice it during normal driving, and does it make the car feel stiffer? I think I can live with the increased vibration in the cabin at idle etc  Thanks a lot guys  Cheers, Nick
#451017 - 17/07/12 06:37 PM
Re: Engine torque link
[Re: ROB IS THE STIG]
the complete engine torque link from vibratechnics makes for a lot on in cabin noise, been told that on here and by by Ford service manager who has experience with these from his rally days I think.
#451018 - 17/07/12 07:53 PM
#451019 - 17/07/12 08:19 PM
[Re: Alex_H]
I should think it would quieten as it wears in a bit Like anything it needs time to settle in
#451022 - 13/09/12 09:49 AM
[Re: Alex_H]
would this also be known as a 'engine gearbox roll restrictor link'  been told to replace mine and im struggling to successfully google
East of England Rep Midge - MG ZR 105 (10-11) Stella - MR200 Fiesta  (11-15) Silky - R171 SLK280 (15 - )
#451024 - 13/09/12 10:13 AM
[Re: kinobeSTew]
any chance you can link me to the replacement rubber parts? Cheers mate
#451025 - 13/09/12 10:24 AM
[Re: sxkopite8]
Loc: Hindley, Lancashire, England
Just having a quick look, eurocarparts ( www.eurocarparts.com) sell two different versions, the cheapest is made by Q-Drive and it looks as though you get the whole unit. This is a better option as the bushes will be quite hard to get in and out and probably require a press to do so. Search for Part No.: 337590770. It's £33.54 but you can use the code on here for 25% off or MIDMONTH30 for 30% off which should make it £23.48.
<center> Click signature to see my Lil Red ST project blog</center>
#451026 - 13/09/12 10:27 AM
[Re: kinobeSTew]
The other one eurocarparts sell is Part No.: 337590775.
I've no idea whether it is a better part or not, i'd go with the cheaper one but that's probably just me being a tight arse.
#451027 - 13/09/12 10:35 AM
[Re: kinobeSTew]
ive never heard of either company  cheers for finding them mate  Anyone else heard of or used Q Drive or Lemforder? Recomendations on quality?
Edited by sxkopite8 (13/09/12 10:36 AM)
#451029 - 13/09/12 11:19 AM
[Re: Burn4]
#451030 - 13/09/12 11:31 AM
[Re: Burn4]
theres only £7 difference between the pair so just interested if anyone had used either company before
#451032 - 13/09/12 12:54 PM
[Re: Ad89]
If you're going to go and pick it up from your local depo then it might be an idea to see which they have in stock as they might only carry one of the two. Just a thought.
#451033 - 13/09/12 01:00 PM
[Re: kinobeSTew]
yeah thats a point, ill check out in advance which they have in stock. How easy are these to fit then?
#451034 - 13/09/12 01:12 PM
[Re: sxkopite8]
Very easy as long as you can get under your car, one bolt goes through each of the rubber bushes. You just undo those and it will fall out. Do it on the flat so that the engine and gearbox don't twist. You can then put the new one in place (push the engine and gearbox using your hand if it isn't quite in the right place) and put the old bolts back in tight.
In advance, have a look under your car and see if you can get to it, you should be able to see it very easily, it's very low down on the car.
#451035 - 13/09/12 01:28 PM
[Re: kinobeSTew]
yeah i may struggle to squeeze under mine  ill have a look later when i get home, cheers
#451037 - 13/09/12 06:02 PM
[Re: kinobeSTew]
I noticed mine was worn on my old fez... Found a low mileage whole replacement for a tenner on eBay
#451039 - 18/09/12 06:55 PM
[Re: Kreaper]
mine was broken when i took it off last year, with only 30k on the clock
#451040 - 18/09/12 07:02 PM
[Re: Dan_The_Man]
what did you get to replace it Dan? bog standard one or a more expensive option?
#451041 - 18/09/12 07:06 PM
[Re: sxkopite8]
#451042 - 18/09/12 07:14 PM
[Re: Dan_The_Man]
It's just a shame they're quite expensive. Can you tell a notable difference specifically from that Dan or did it just feel "fixed" given your other one had broke?
Would be good if we could get a group buy going. Are there a few people wanting one?
#451043 - 18/09/12 07:28 PM
[Re: kinobeSTew]
when you 1st fit it the car does wobble on idle, buts it settles in and you notice the little hesitation when accelerating disappears and feels a lot more responsive
#451044 - 18/09/12 07:39 PM
[Re: Dan_The_Man]
 don't know wether to go cheap or not
#451045 - 19/09/12 06:12 AM
[Re: sxkopite8]
Ahh that's interesting, I hate that when you floor it and it takes a split second to do anything. I always put it down to the ECU trying to "think" whether it's a good idea. Lol.
#451046 - 19/09/12 09:28 AM
[Re: kinobeSTew]
Yeah i'd be interested in one
#451047 - 19/09/12 10:13 AM
[Re: Jack_P]
shall we start up a dedicated group buy post?
#451049 - 19/09/12 12:11 PM
[Re: gary4vicky]
either someones tells you the bushes are split or you take it off and find out for yourself  dont think there is a way of telling while driving unless it all fell apart
#451050 - 19/09/12 08:14 PM
[Re: sxkopite8]
you start getting a knocking noise if it totally goes
#451052 - 19/09/12 09:37 PM
[Re: Mean_ST]
Yeah, lets see if we can get a decent group buy price. We can set up a group buy thread definitely.
I have a feeling mine is either worn or a bit split, the engine twists quite a bit. Especially when I was on the rolling road, moreso than anyone elses.
#451054 - 20/09/12 06:37 AM
[Re: CJ_]
I'll email pumespeed when I get into work and see if we can get a price
#451055 - 20/09/12 10:07 AM
[Re: sxkopite8]
Well Burton Power sell 2 different versions, a HD (fast road) and a competition. The competition is the more expensive (but not by much) and is £136.44. Less than the £139 pumaspeed charge for what I assume is the fast road version.
Probably worth trying a few different places including vibratechnics themselves. If we get enough of us together they might sell direct at a good price.
#451056 - 20/09/12 12:35 PM
[Re: kinobeSTew]
ive emailed Pumaspeed, Burton Power and Vibra technics. Hopefull will get a positive response. If we do then ill set up a group buy in the lot
#451057 - 15/04/13 08:17 PM
[Re: sxkopite8]
thought id update this page, had the vibratechnics link on for a couple weeks now. most people ask about the vibrations, yes, on startup it does sound violent but definitely calming down already and not massively noticeable during driving, altho mine does idle quite aggressively due to the mountune kit so i may not be best opinion there  in terms of driving, the gear changes are definitely better, the little hesitation that i hated when changing gears has gone, its now very smooth and a lot quicker because of it. were talking fractions of a second here but for those who do want to squeeze everything possible out of their car pacewise then id recommend it
#451059 - 15/04/13 09:06 PM
[Re: nosnow3]
does your link need replacing? i only changed mine as i had been told the original bushes in mine had split.
#451060 - 15/04/13 09:20 PM
[Re: sxkopite8]
make a vid of the start up noise, is there any other noise from it when driving or changing gear, or just on start up ?
#451063 - 15/04/13 09:31 PM
[Re: dontpannic]
it only occurs when directly starting the engine, loud thump a couple times before the engine ticks over, this has definitely calmed down as the bushes bed in. the vibrations only occur when driving at very low revs, 1500 mark ish.
#451064 - 15/04/13 09:51 PM
[Re: sxkopite8]
Did just try a quick video but can't notice it all
#451065 - 15/04/13 10:13 PM
[Re: sxkopite8]
its not that bad, i dont ever notice mine anymore, i have had it on there for ages now
#451066 - 16/04/13 09:26 AM
[Re: Dan_The_Man]
At 30k I don't think it will do, unless age comes into it. Mines an 05
1694
