#458156 - 17/08/12 08:40 PM need some sticky stuff
can't make my Gel badge stick to my glovebox handle, tried 3M spray adhesive but not strong enough, any other better spray adhesives that won't mark the plastic handle ? Double sided sticky tape perhaps ?
#458157 - 17/08/12 08:42 PM Re: need some sticky stuff [Re: YellowBadge]
Chrisjs84 Offline
Loc: Lancaster
Need some 3M double sided tape Steve, that should hold it!
#458158 - 17/08/12 09:12 PM Re: need some sticky stuff [Re: Chrisjs84]
need very thin though otherwise won't look flush, will do some googling.
#458159 - 17/08/12 09:13 PM Re: need some sticky stuff [Re: YellowBadge]
ST_Jonny Offline
Numberplate tape?
#458160 - 18/08/12 06:31 AM Re: need some sticky stuff [Re: ST_Jonny]
Steve, get hold of a roll of carpet tape, its thin, transparent, double sided and crazy sticky!!!
#458161 - 18/08/12 06:02 PM Re: need some sticky stuff [Re: ROB IS THE STIG]
ok will check it out
#458162 - 18/08/12 06:08 PM Re: need some sticky stuff [Re: YellowBadge]
B&Q mate
Bloody awesome stuff
#458163 - 18/08/12 08:59 PM Re: need some sticky stuff [Re: ROB IS THE STIG]
ok
#458164 - 23/08/12 04:18 PM Re: need some sticky stuff [Re: YellowBadge]
double sided carpet tape won't work, fell off next morning, just trying two layers of the stuff now. Just won't stick to plastic.
#458165 - 23/08/12 04:24 PM Re: need some sticky stuff [Re: YellowBadge]
enforcer Offline
Good ole glue!
#458166 - 23/08/12 05:52 PM Re: need some sticky stuff [Re: YellowBadge]
Really??
Its been on my number plates for years, no issue at all
#458167 - 23/08/12 07:21 PM Re: need some sticky stuff [Re: enforcer]
Good ole glue!
glue is too lumpy, won't leave the badge sitting flush.
#458168 - 23/08/12 07:32 PM Re: need some sticky stuff [Re: ROB IS THE STIG]
Really??
it's certainly stick stuff, just not good on shiny smooth plastic that is the glovebox handle, of which I don't want to sand to rough up, will see in morning if it drops off again, not sure if there are higher adhesives tapes, I just got a small roll of cheapish stuff, "supaDec" made by Supabrands I think.
#458169 - 23/08/12 08:04 PM Re: need some sticky stuff [Re: YellowBadge]
enforcer Offline
If you plan on keepin the badge on. then sandpaper the handle a little to create a rough texture then the adhesive should work fella
#458170 - 24/08/12 02:41 PM Re: need some sticky stuff [Re: enforcer]
in the post above mate, steve doesn't want to do that........
#458171 - 24/08/12 02:57 PM Re: need some sticky stuff [Re: ROB IS THE STIG]
enforcer Offline
My bad. Should have read this fully
#458172 - 24/08/12 05:57 PM Re: need some sticky stuff [Re: enforcer]
off it came today but lasted longer, going to try multiple layers of the sticky on the premise that more will hold onto the handle and more to the badge. I've got 5m of the stuff, might as well use it...............
#458173 - 24/08/12 08:06 PM Re: need some sticky stuff [Re: YellowBadge]
A windscreen mirror sticky pad, probably a bit thick though
A dab of silicone? Will always come back off
#458174 - 01/09/12 09:17 PM Re: need some sticky stuff [Re: Adam08]
so far has stayed on, it now has about four layers of the double sided carpet tape.
