#467735 - 23/09/12 08:47 AM remap for mil light?
owningmilo07 Offline
Loc: Somerset
just a quick question as to whats the best map to get for my fiesta if i have the mil light on and i cant remove without other ways.
heard a few maps delete it but it comes back on after a while so i dont want that =[
im running milltek manifold and sports cat and powerflow cat back =] and a k and n cone filter
thanks in advance milo
done
all aero wipers
dmb badges
lenso d1r's matt black
eibach 35mm springs
HIDs
wind deflectors
custom carbon fibre splitter
milltek manifold powerflow cat back
tints
custom focus rs bonnet vents
#467736 - 23/09/12 10:11 AM Re: remap for mil light? [Re: owningmilo07]
I've got an elbow to put on the 2nd 02 sensor so it doesnt pick up the fumes as much, should make it go off
#467737 - 23/09/12 11:04 AM Re: remap for mil light? [Re: Jack_P]
Hmm, exactly the setup I had! My light was caused by wiring that had melted on one of the sensors though so a new sensor or further sensor related investigation may sort it.
However, I had an Evolution Chips remap and it got rid of the light for good and the car ran well
#467738 - 23/09/12 02:26 PM Re: remap for mil light? [Re: ST_Lee]
Loc: Somerset
il check the fault codes and see what pops up if it emissions il leave for a few hundred miles and if doesnt then il probs map it. how much was the map??
done
all aero wipers
dmb badges
eibach 35mm springs
HIDs
wind deflectors
tints
#467739 - 23/09/12 02:37 PM Re: remap for mil light? [Re: owningmilo07]
This would be better in the Technical Section guys
#467740 - 23/09/12 02:40 PM Re: remap for mil light? [Re: ROB IS THE STIG]
Loc: Somerset
woops my bad i forgot we had that section =[ mod switch it please =]
done
all aero wipers
dmb badges
eibach 35mm springs
HIDs
wind deflectors
tints
#467741 - 23/09/12 02:54 PM Re: remap for mil light? [Re: owningmilo07]
no worries mate, could be v useful to others so not ideal hidden to non members
#467742 - 23/09/12 03:50 PM Re: remap for mil light? [Re: ROB IS THE STIG]
To be fair, people may not be joining because they get all their info for free - so there's no need.
Just a thought
Remap was £350 mate
#467743 - 23/09/12 03:55 PM Re: remap for mil light? [Re: ST_Lee]
fair enough but i think the members section has lost its meaning tbh
Anyway, back on topic.......
Remap
#467744 - 23/09/12 04:00 PM Re: remap for mil light? [Re: ROB IS THE STIG]
Evolution Chips is a custom map - the guys that did it for me knew about my problem and deliberately found and deleted the relevant file that was causing the error
#467745 - 24/09/12 11:58 AM Re: remap for mil light? [Re: ST_Lee]
moved as requested by owningmilo07
#467746 - 24/09/12 12:49 PM Re: remap for mil light? [Re: kenny]
kinobeSTew Offline
Loc: Hindley, Lancashire, England
Mine is on at the moment and i'm thinking of trying one of these off ebay:
http://www.ebay.co.uk/itm/LAMBDA-O2-OXYG...=item27cb05bc40
Not sure if it will work, but i'll give it a go.
Information i've gathered from other sources which you may find useful:
- It is the 2nd lambda sensor causing the light to come on.
- The 2nd lambda sensor simply detects whether the emissions have fallen by enough when compared to the 1st lambda sensor to indicate that the cat is working correctly.
- As such, it is just a diagnostics sensor and it has no bareing on air/fuel ratios or anything else engine running related. This is different from the 1st lambda sensor which does control these things.
- You can't just remove or leave the sensor picking up clean air otherwise it detects this and gives a "no activity" type code with the light back on.
- The sensing occurs over a period of time, so its not a sudden reading, hence why it can take a hundred+ miles for it to change.
- Some people have used the spacers i've linked to in the above ebay link to good effect, but only on other cars (Civics are one). As Jack said above, they work by holding the sensor further away from the bad emissions so the sensor picks up less.
Not sure whether the spacer would work for definite on a Fiesta ST.
<center>
Click signature to see my Lil Red ST project blog</center>
#467747 - 24/09/12 01:09 PM Re: remap for mil light? [Re: kinobeSTew]
i also need one of these as my light stays on and a better price then pumaspeed
#467748 - 24/09/12 01:31 PM Re: remap for mil light? [Re: kenny]
kinobeSTew Offline
The pumaspeed part (if the same as the one for the Fiesta ST) works in a different way though hence why it is more expensive. The pumaspeed one connects between the wiring and the sensor and has a resistor in it which makes it appear as though the sensor is outputting the correct signal even when it isn't.
<center>
#467749 - 24/09/12 01:33 PM Re: remap for mil light? [Re: kinobeSTew]
kinobeSTew Offline
For completeness, i'll add that another alternative for making the light go off is a unit that looks very similar to the spacer I posted a link to above but it has a very small catylytic converter built in so that it processes the bad emissions and makes them good for the sensor. Only seen a couple of these for sale though, they seem hard to find.
<center>
#467750 - 24/09/12 02:50 PM Re: remap for mil light? [Re: kinobeSTew]
Stew are you sure it can be a straight fitting and not needing an elbowed version?
Only reason i ask is because i need one and the guy who fitted mine said get an 9deg elbow instead as it will stigk out to far and not fit.
#467751 - 24/09/12 03:07 PM Re: remap for mil light? [Re: Jack_P]
kinobeSTew Offline
No, i'm not sure. It's a good point Jack. I probably should have added that I don't even know if it will fit.
I just found the ones which looked the best made on ebay. From what I can gather, some people have had problems with the sensor not getting enough fumes which will cause the light also hence why I thought a 90degree one might not work. Hmm....might have to get under the car and see how much room there is unless anyone has a photo?
<center>
#467752 - 24/09/12 04:18 PM Re: remap for mil light? [Re: kinobeSTew]
Its just what the guy from work who put mine on told me. Another guy, his mrs runs a decat system which he said he has the elbown on and its never come on
Found this picture of stasons Sportcat which is same as mine, looks as if it goes out upwards and to the right ( if you're looking from the rear )atleast the elbow will send it off sideways and not into the floorpan!
Just found a photo of a decat pipe, it appears it goes straight up so i can imagine you will need an elbow instead!
#467753 - 25/09/12 11:34 AM Re: remap for mil light? [Re: Jack_P]
kinobeSTew Offline
The latter is me, hehe. Found any decent elbow ones? I would quite like a stainless one so it doesn't corrode and get stuck.
<center>
#467754 - 25/09/12 05:10 PM Re: remap for mil light? [Re: kinobeSTew]
Loc: Somerset
thanks for the move kenny =]
i got it checked and the codes are
p0126
p0128
both are to do with 2nd o2 sensor
but not sure what lol
i found the descriptions on this forum yesterday but now lost them =[
done
all aero wipers
dmb badges
eibach 35mm springs
HIDs
wind deflectors
tints
#467755 - 25/09/12 06:14 PM Re: remap for mil light? [Re: owningmilo07]
Loc: Somerset
edit!!!
p0136 and p0138 =]
plus found this
http://www.fordfiestast.co.uk/showflat.php?Number=153855
do i need to just wait??
done
all aero wipers
dmb badges
eibach 35mm springs
HIDs
wind deflectors
tints
#467756 - 25/09/12 08:01 PM Re: remap for mil light? [Re: kinobeSTew]
get some copper slip paste on the thread and it wont seize in there, stainless is the better shout!
0 registered (), 1518 Guests and 0 Spiders online.
