#556313 - 13/07/15 09:07 PM
New to the forum - Buying Advice
Hi Guys,
Always found forums the best place for advice and I am in need of some.
I am considering buying a Fiesta ST and have a couple in mind. Is there anything that I should be looking out for. I plan on buying one from a dealer (Not Fords) so I get a warranty.
I'm keen to know any common faults that I should look out for.
Fingers crossed I will be an ST owner in the next few weeks.
Russ
#556316 - 13/07/15 09:41 PM
Re: New to the forum - Buying Advice
[Re: DaveGotNoRave]
Thank you for a quick response. I am keen to get one of these but have been burnt before when buying second hand cars, more research needed I heard horrible stories of the bottom end going on these cars, however as you have said it depends on how it was looked after before. Thanks Russ
#556318 - 13/07/15 09:53 PM
[Re: MrRussells]
I've never heard much serious going wrong with the Fes ST, odd gearbox spitting a gear through casing, coil packs can go, driver side seat catch likely broken, just to flimsy to incline a heavy seat, check both sides. Some bad tyre wear if tracking out. Had mine 8 years from new, had a seized rear caliper replaced and still on factory pads/discs and only this year a new battery. Albeit I now have an engine warning light twice in as many months, worse case senario for me is the MR200 updates are taking a toll on the PCM which won't be cheap. Get a low miles one, few drivers, older owners better, check oil, look for leaks, look for clean and clear fluids, good gear change etc, no smoke all usual basic stuff, would be a good buy now too.
#556416 - 19/07/15 05:22 PM
[Re: MrRussells]
Loc: Northwest
Cool!
2005 Fiesta ST - wrote off Newman fast road cams, Fusion Fabrications custom inlet manifold, custom exhaust
#556428 - 20/07/15 02:52 PM
[Re: MrRussells]
#556493 - 21/07/15 11:05 PM
[Re: MrRussells]
Thank you absolutely love the car. It really is best of both worlds. I get 37 mpg to and from work but its still so fun. Do need to check the AC though as its not cold at all.
#556529 - 23/07/15 05:49 PM
[Re: MrRussells]
Loc: Northwest
Not sure if this is what you're hearing but I think a few s make a funny noice at low throttle, and at a certain revs. Mine does it - although never in 1st. Not sure what causes it.
#556539 - 23/07/15 07:48 PM
[Re: MrRussells]
Had my dad have a look and he thinks it could just be the fact it was getting hot as I was in stop start traffic. Bloody roadworks. Anyone else have this ?
#556541 - 23/07/15 07:50 PM
[Re: MrRussells]
Thank you for your reply Jimmy. In had so many problems with my vw golf I am on edge with any noise
#556551 - 23/07/15 09:34 PM
[Re: MrRussells]
air con is naff in the ST, mine was poor from new, had it serviced recently not sure what they did but after 8 years I now finally have cold air and it's great, not icy cold like some but for certain proper cold. TB doesn't make much noise, probably only hear it's actuations if bonnet up, power steering can whine, mine never has. If you on PZero tyres they can judder from the off, too hard will last but awful in damp/wet and as I say don't grip initially, you need to get grip then plant it.
#556552 - 23/07/15 09:55 PM
[Re: MrRussells]
I did read somewhere that the reccomended dosage ha-ha is about 450 however this was a mistype by ford and should be 650. If you get it charged to that the aircon is good.
564
