#59247 - 04/12/06 11:21 AM Car problems
Krazy_Kath Offline
Loc: Stockport
Ok, my ST has been in the garage on 2 occasions now and it's still not been sorted
It doesn't start up all the time, it ticks over but doesn't fire up. Also there's a really bad squeek coming from what sounds like the rear Last time it was suppose to have had all the suspension greased to stop it, stopped for a day and now it's squeeking again.
Also the clutch makes a noise and it's not just a case of putting some WD40 on it, as already done this! There's also some really strange marks on the inside of the window. These aren't the lines to heat it, they're weird, and I've tried cleaning it with alsorts!!
Going to call Ford tomorrow and tell them, yet again it's not sorted!
Why can't they simply sort it first time round......oh yeah because they're useless
Edited by Krazy_Kath (04/12/06 11:25 AM)
Krazy Kath!! 1/4 mile - 16.4 @ 82mph......this will be beaten!!
#59248 - 04/12/06 12:02 PM Re: Car problems [Re: Krazy_Kath]
Mase Offline
Start up - I've never experienced this, but know many have, don't know a fix
Squeek - Have you tried parcel shelf and seat belt reels, both are commonish problems and could make a squeeking noise
Clutch - Mine squeeks, I haven't done anything about it yet, apparently there is a sheathed spring mechanism that you can get fitted, but I am no too sure on this.
Window - Are they like sucker cup sort of marks? This is how they put the window in and I have yet to get the mark totally gone.
Also have you tried using different dealers, the service can change quite a bit!
#59249 - 04/12/06 12:36 PM Re: Car problems [Re: Mase]
Krazy_Kath Offline
Loc: Stockport
Wasn't sure if I could take it to another dealer to be honest. But I think that I'm going to have to try. There's another one closer to me anyway!
I'll have a look at the seat belts and see if that's the issue.
The marks on the window are weird, there's loads of lines, which you can only really see if certain lights. I've tried cleaning it loads but it just won't go. They're not sucker marks!
Thanks for repsonding
#59250 - 04/12/06 01:13 PM Re: Car problems [Re: Krazy_Kath]
MichaelST1 Offline
Is the squeak like rubber on rubber? I had a loud squeak from the o/s/r and the dealership refitted the lamp assembly and lube the shock absorber.
#59251 - 04/12/06 01:31 PM Re: Car problems [Re: MichaelST1]
Krazy_Kath Offline
Loc: Stockport
Not really. Not to sure what it is yet
#59252 - 04/12/06 03:15 PM Re: Car problems [Re: Krazy_Kath]
wapSTer Offline
Loc: glasgow
is it the front windscreen with the lines???
i heard the squeeking noise was supposed to be something to do with the rear seat belts where they attach to the car,simple to fix so i was told mines been fine so never checked...
I INTEND ON LIVING FOREVER,SO FAR SO GOOD...
#59253 - 04/12/06 03:48 PM Re: Car problems [Re: wapSTer]
Do have a noise sometime in my car but I think its coming from the dashboard! For the starting problem same for me not solution yet! and on my front windows do have a line in the middle but it look like grease and everytime I lower the window the mark does come back!
#59254 - 04/12/06 04:00 PM Re: Car problems [Re: Krazy_Kath]
Iceman Offline
Loc: Bradford.
kath,
i agree with you totally believe me when i say this if when i get my car
back this time,it happens again,be prepared 4 headline news seriously now
i am not prepared to put up with this s..t any more,watch this space.
iceman.
p.s. a 2 month old car with less than 1500mls on clock,no more.....
on my 2nd st.
#59255 - 04/12/06 04:19 PM Re: Car problems [Re: Iceman]
Krazy_Kath Offline
Loc: Stockport
Yeah the windowscreen has like greasy likes all over it but I can't get rid of them!
Oh and babyboom I've always got a squeeky noise coming from the dashboard, but that's the least of my worries!!
I'll be calling them tomorrow and if something's not sorted the s**t will be hitting the fan big time
#59256 - 04/12/06 04:59 PM Re: Car problems [Re: Krazy_Kath]
SI_ST Offline
Loc: Yorkshire
I used to have the starting problem but it seems to have gone away after putting some milage on the car or an ECU update helped. Perhaps the starter motor/fuel pump needs bedding in.
#59257 - 04/12/06 05:17 PM Re: Car problems [Re: SI_ST]
Krazy_Kath Offline
Loc: Stockport
Yeah something seriously needs sorting. Can't afford to be spending all the money on a car for it not to work properly!!
#59258 - 04/12/06 05:30 PM Re: Car problems [Re: Krazy_Kath]
Kath,
The clutch just needs a good grease, i've had the same problem.
I have 2 circles on both front windows and i clean them, they go away and then come back again... no way of getting rid of them... just accepted them
The none starting is a common problem, just stop, wait 5 secs and it will power up. won't do anything about this.
Deff get the suspension done!!!
#59259 - 04/12/06 06:19 PM Re: Car problems [Re: Scotty]
Yup, I had the same problem early on, asked for it to be sorted at the 3 month service, they greased it properly, and I've never had the problem since.
Yes, just turn the key to II, wait until the lights go out on the dashboard and it should definitely start then.
#59260 - 04/12/06 06:50 PM Re: Car problems [Re: ChrisCumbria]
andytran Offline
Loc: Peterhead, Northern Scotland
I totally agree....I always wait for the lights to go out before starting and havent had any problems. Apparently, Fords have an issue whereby the immobilser doesnt disengage quick enough. If you wait for the lights to go out, it gives the car time to sort its life out!
Iceman, Hope you get sorted but dont look to Ford to solve your problems with any compassion. I bought a brand new 2.0TDCi Ghia Focus last year - It broke down within hours and went on to breakdown a further 12 tiomes in the first year. Ford couldnt sort it and to be honest, didnt give a toss. I traded it in for the ST. If this one gives me grief, it will be the last Ford I EVER own. So far the cars been great, 1200miles in and running well.............please dont tell me Ive spoken too soon!
Andy
Edited by ChrisCumbria (04/12/06 06:52 PM)
#59261 - 04/12/06 08:05 PM Re: Car problems [Re: ChrisCumbria]
Thats what they told me at my dealer and also start my car and told than after 25 starts in a row that the car got difficulty starting they try it on my car!!
#59262 - 05/12/06 12:20 AM Re: Car problems [Re: Krazy_Kath]
Iceman Offline
Loc: Bradford.
funny you should mention those weird looking lines on the inside of your
windscreen as i have noticed the same on mine,however its more prominant when
there is a condinsation build up on the windscreen.when its dry the marks go!!!!
iceman.
on my 2nd st.
#59263 - 05/12/06 09:15 AM Re: Car problems [Re: Iceman]
Krazy_Kath Offline
Loc: Stockport
iceman.
Yeah generally you can't see them it's when it's steamed up!
#59264 - 05/12/06 10:12 AM Re: Car problems [Re: Krazy_Kath]
Yehhhh I get them too... Its just where the window goes up & down and gets marked (not scratched!). The condensation just picks them up
#59265 - 05/12/06 01:03 PM Re: Car problems [Re: PinkRinse]
RobCorsa Offline
Loc: Stockport
What do you mean the window goes up and down... its the windscreen not the door windows.
Its almost looks like glue because you can feel the marks when you rub your fingers over them, very weird, will take a pic next time it happens
Corsa C 2.0L XE
#59266 - 05/12/06 04:18 PM Re: Car problems [Re: RobCorsa]
Ohhhh ... stupid me not reading Kath's earlier post!
#59267 - 06/12/06 08:24 AM Re: Car problems [Re: PinkRinse]
Krazy_Kath Offline
Loc: Stockport
I'll let you off hun
0 registered (), 1566 Guests and 0 Spiders online.
