PinkRinse
Quote: Jam Sport and Pumabuild offer the 2.3L Duratec engine swap...
*aHEM* .... echo... echo...! Hello? As far as I know it a 2.3L engine not a bored out 2L. Imo I doubt the Focus ST engine will fit. The 2.3L eninge does *just* as its only a tiny bit taller.
_________________________ 24/03/05 to 27/06/12 & I loved it
with a little bit of chopping and welding anything could be possible, but why the sudden change i thought you were seriously considering selling it? and you definantly loose your warranty then
Tony
Loc: Kirkby-In-Ashfield, Notts
LOL no i wouldnt lose my warranty its a ford engine in a ford car
Just when you go hacking the exhaust to bit and fitting induction kits it seems to brake things eh adam
Was just wondering cos id love to put the time/effort and money into having a Fiesta with a 2.5l turbo engine would put A-pillar gauges on it from the Focus dash and a MAHHHOSIVE dump valve everything would be very... err different
Anyway im not selling her now could never part with her
"How far is it now Kev?"
"7 miles!?"
babyboom
Quote: LOL no i wouldnt lose my warranty its a ford engine in a ford car
Was just wondering cos id love to put the time/effort and money into having a Fiesta with a 2.5l turbo engine would put A-pillar gauges on it from the Focus dash and a MAHHHOSIVE dump valve everything would be very... err different Anyway im not selling her now could never part with her
fit a cosworth engine in it! they small 2L 4cylinder!!
Tony
But there old engines whereas a Focus engine would be nearly new to match the car its going in no point putting a really old engine in a new car
"7 miles!?"
babyboom
its not that old and they easy to mods or fit in cars!!
Just whack a Turbo on the standard ST engine you already have. You'll still get the opportunity to fit your "MAHHHOSIVE dump valve" and there surely is already a kit available which would cost less than an entire engine swap.
You'd be in for major mods to fit a Cosworth engine to the Fiesta as the YB engine is designed for longitudinal fitting so turning it around 90 degrees to fit the Fiesta box would be a hell of a job. Alternatively you could simply fit it lengthwise complete with the cossie box but again you'd be in for major mods and probably at making it RWD...
babyboom
you can buy fake dump valve!! it make a sound of a dump valve but its for non turbo engines! and u can even activated anytime u want as its just a sound!
I really don't think you'd get the T5 engine to fit the Fiesta engine bay as it's too long. Though, as said, anything is poss with a hammer and a mig welder. I used to have a friend who had a MKII Escort with a capri 3.0 V6 engine in!!
If you're desperate to depleat your bank balance and have a fixation on replacing clutches, gearboxes and driveshafts then you may want to consider shuvving in the lump out of a Mazda 6 MPS. It's the 2.3 version of our Duratec (so it's a 4cyl) and it's turbo'd. Should connect straight up to your gearbox (for a while) but you would have to get the Mazda's ECU wired in to run it properly. You should push about 250 BHP in standard form and 300 -350 torque, don't quote me though, It may be more. A limited slip diff will not prevent the gearbox from exploding with the torque so don't waste your money. I would have the ECU mapped so you get a reduction in torque on 1st and 2nd gears, that should make it last a bit longer
mines all fixed now, however i didnt think that ford would honour a warranty on the engine swap, but you must of done your homework on it. mine goes on the dyno nxt week so ile let u no how i get on . keep us posted on your progress though.
