#77026 - 11/03/07 06:47 PM Advice on Panel Repair...
willST06 Offline
Loc: Portsmouth
Evening guys,
A few months back some dip-sh*t went into the side of my drivers door. He was an old git and wasn't all there. I got the panel fixed under an insurance job as it was dented and badly scuffed. The insurer's preffered repairer was Nationwide Crash Repair (NCR). They repaired it to a very good standard, however a couple of months later I had the door kicked (minor domestic) lol. This caused a slight dent in the door so got a local dent firm to come out and fix it.
All was well, until I washed the car and I applied a bit of pressure, as you do when you clean the car and the dent went back in again! So got another guy out to undo the dent again.
Washed the car today, and you guessed it, the dent went bak in again.
I cannot continue with this - I need it sorted!
The panel is now pretty "flimsy" i.e. if I use my fingers and push on the panel it warps if you get my drift - it is certainly not as strong as the original door on the other side.
Question: What do you suggest I do 'cos I don't fancy getting a dent guy back out because I know it will just happen again.
Do Ford repair panels or will it have to be a new door, knowing ford. And I know how much a new door will cost with the dealers?
Or should I find a local bodyshop repairer who can just put another new panel on? Any ideas on price?
Although I would prefer Ford to do the work as I trust their workmanship!
Hope you can help guys & gals.
(A fed up) Will.
#77027 - 11/03/07 07:16 PM Re: Advice on Panel Repair... [Re: willST06]
Well...............
A new door will cost you the price of a new door £300??, plus fitting (including disassemby and reassembly) and spraying.Another £300??
A new skin isn't really recommended on a new car, it's better to have a new door
but it's your car £300??
You could get a 2nd hand door from a scrappy£50-100??, disassemble it yourself, take it to a bodyshop and have it sprayed £150 then reassemble and fit it yourself??
You'd be suprised how easy it is to build a door up
Your choice mate
#77028 - 11/03/07 07:25 PM Re: Advice on Panel Repair... [Re: DAVE T ST]
willST06 Offline
Loc: Portsmouth
Well...............
Your choice mate
Yeah your estimate for a new door is about right - the exact figure HENDY FORD FAREHAM charge is £935.63 (so much money!!!!)
Can I ask why its not recommended that they fit a new panel on a new car?
#77029 - 11/03/07 07:34 PM Re: Advice on Panel Repair... [Re: willST06]
God that is dear!!
Alot of independant body shops have just as good spraying facilities and colour matching as a Ford dealer.
Shop around
When you cut the door skin off a car it weakens the door frame.
It's not major, but it's not the type of thing I would want doing on a new car.
I would rather get a good 2nd hand door, if I was on a tight budget, than have a new door skin.
It's my opinion that's all
#77030 - 11/03/07 08:04 PM Re: Advice on Panel Repair... [Re: DAVE T ST]
willST06 Offline
Loc: Portsmouth
Yeah exactly! the panel is a load of poo now. I don't know if I have any confidence in other independant bodyshops!
Will have to look at my finances.
#77031 - 11/03/07 08:20 PM Re: Advice on Panel Repair... [Re: willST06]
yes probably better 2 buy a second hand door if ur on a budget otherwise get a new door and u will have great job done! but if second door is done probably then u will save money!!
#77032 - 11/03/07 08:21 PM Re: Advice on Panel Repair... [Re: willST06]
Biff Offline
Loc: Portsmouth, Hampshire
Will. Don't use Hendy's.....a right bunch of cowboys!! will never deal with them again after my last Fiesta. Try Daron's on Hayling. Been using them for past 5years and can't fault them!
#77033 - 11/03/07 08:23 PM Re: Advice on Panel Repair... [Re: Biff]
willST06 Offline
Loc: Portsmouth
Biff - do Darons at Hayling repair though? I went past their today, it didn't look like they had a repair centre?
#77034 - 11/03/07 08:29 PM Re: Advice on Panel Repair... [Re: willST06]
Biff Offline
They do indeed. They've have done work for me before. Ask to speak to John Simmons and tell him that I (Darrin Corbin) recommended them. Can't say that the price will be much better than Hendy's (don't get me started on them C**nts)but the service etc is second to none.
#77035 - 11/03/07 08:43 PM Re: Advice on Panel Repair... [Re: Biff]
willST06 Offline
Loc: Portsmouth
Thanks Biff,
Will bear this in mind, the only downer is that Hayling Isl. is a bit out in the sticks for me.
#77036 - 11/03/07 08:56 PM Re: Advice on Panel Repair... [Re: willST06]
Biff Offline
I can only assume that you don't drive very far then!!? Its worth speaking to them though
#77037 - 11/03/07 09:00 PM Re: Advice on Panel Repair... [Re: Biff]
willST06 Offline
Loc: Portsmouth
Well I do its just that If I did decide to use them instead of Hendy then I would have to think about how I would get back home and back to Hayling Isl once the car is repaired.
Getting a hire-car would just add to the cost for me.
I have had repair work done at Fareham and I must say the customer service skills were execellent and the work was much better than an independant. But can only speak for myself.
#77038 - 11/03/07 09:44 PM Re: Advice on Panel Repair... [Re: willST06]
Biff Offline
ok mate. speak to both of them is the best idea. I just hate Hendy's with a passion. I very nearly had to take out legal action against them
#77039 - 11/03/07 10:04 PM Re: Advice on Panel Repair... [Re: Biff]
willST06 Offline
Loc: Portsmouth
Doesn't sound too good! Anyway I know this sounds a bit of a dumb question but if I choose Hayling Isl or Fareham for that matter do you get a courtesy car free? Or do you have to pay for it whilst in repair, as far as I know you have to pay?
Ref HENDY FORD: I have found the Bodyshop manager there very good (Steve O Boyle).
I know how much HENDY FORD FAREHAM charge for the full repair so all i need to do is go to Hayling Isl. to get a second to compare.
I doubt there will be much difference.
#77040 - 11/03/07 10:34 PM Re: Advice on Panel Repair... [Re: willST06]
Biff Offline
Cant answer that for sure. I know I would get a courtesy car for free but then I bought my ST from them.
#77041 - 12/03/07 05:57 PM Re: Advice on Panel Repair... [Re: Biff]
willST06 Offline
Loc: Portsmouth
Hey Biff: This will make you laugh - I went to Darons Ford at Hayling Island today after work and I told them about my dilema with the door panel.
Well, they can either repair the panel - which will cost around 200-300 quid, which I didn't think Ford could do. Hendy Ford Fareham certainly would not repir a panel.
And he also gave me a quote for a NEW DOOR......£711.00 inc VAT. I also have spare side decals indoors so this will shave £30 odd quid off this!!
So it does pay to shop around as I have already said Hendy Ford (Fareham) have quoted a new door at £935.63 inc VAT.
So thats at least a 200 quid saving! Cant complain.
Im glad he offered my the two quotes of panel repair / and new door. Quotes are in the post and will be up to me.
Either way Im going with Darons Ford. Job well done there.
