#105899 - 02/10/07 02:50 PM Squeaky Clutch Pedal
___b Offline
Loc: Glasgow , Scotland
Hi,
My car is in ford just now had a new air sensor fitted and i am awaiting a instrument cluster coming in to be fitted too.
I have a squeaky clutch pedal and i asked if they could sort it out and they told me that the car is outwith the 1 year warranty for this?? Is this nonsense ???
If anyone has had the same problem is it easy to fix ??
B.
#105900 - 02/10/07 03:27 PM Re: Squeaky Clutch Pedal [Re: ___b]
n3ldv Offline
yeh mines does that found the easiest thing to do was just turn up the music problem fixed
#105901 - 02/10/07 04:10 PM Re: Squeaky Clutch Pedal [Re: n3ldv]
FluffySheep Offline
Loc: Staffordshire
Mine does it too, and I also just turn the music up lol.
Swansea City AFC - League One Champions 2007-2008 Carling Cup 3rd Round....Swansea 1-0 Cardiff....JACK ARMY!!!
#105902 - 02/10/07 04:16 PM Re: Squeaky Clutch Pedal [Re: FluffySheep]
Mine done this, Just got down behind the pedal and squirted some good old wd40 on it.
#105903 - 02/10/07 09:38 PM Re: Squeaky Clutch Pedal [Re: Micky]
JamesUK Offline
Loc: Worcester, UK
I don't have a squeak as such, but i do have what .... what i can only describe as the springy noise when i used to press the accelerate trigger on the old scalextric controller.
#105904 - 02/10/07 09:51 PM Re: Squeaky Clutch Pedal [Re: JamesUK]
Anthony1664 Offline
the squeeky clutch/spring noise is a "feature" i think all Mk6's have it just have to keep greasing or WD40ing it
The Mk6 Fiesta st grew in size & became a Mk3 Mondeo st it now it's shrinking to a Mk3.5 Focus ST3
#105905 - 02/10/07 09:59 PM Re: Squeaky Clutch Pedal [Re: Anthony1664]
If its treat properly then it should be solved. Mine squeaked when I first got it and I asked to dealer to sort it out. They sprayed something on it, not sure what, and its been fine ever since (over two years now).
#105906 - 02/10/07 10:20 PM Re: Squeaky Clutch Pedal [Re: JamesUK]
FluffySheep Offline
Loc: Staffordshire
That's the exact noise mine makes!
#105907 - 02/10/07 10:54 PM Re: Squeaky Clutch Pedal [Re: FluffySheep]
ben_st Offline
Loc: Gatwick, UK
Yup mine too. This is my second ST and both of them did it.
#105908 - 03/10/07 01:04 PM Re: Squeaky Clutch Pedal [Re: ben_st]
STeve Offline
mine does it too - was solved by the garage with some lubricant of some sort however about 2 months later its back!! - will try the WD-40 down the back of the pedal
#105909 - 03/10/07 05:01 PM Re: Squeaky Clutch Pedal [Re: STeve]
STifler Offline
Loc: Warwickshire
think its a common fault on the fiesta in general. Its just a simple oil job and the squeak should go away
find it hard to believe how they are counting it as an interior trim fault when its more mechanical
Frozen white Fiesta ST you see this name you think dirty
#105910 - 06/10/07 09:03 PM Re: Squeaky Clutch Pedal [Re: STifler]
williamthorpe271 Offline
Hi, FYI squeak ( spring noise ) comes back every time with WD 40,use Castrol chain wax spray or something similar and it will be cured. its awkward to spray, i used a small mirror to see to top of pedal. Aim for pivot pin and spring.
#105911 - 07/10/07 03:59 PM Re: Squeaky Clutch Pedal [Re: williamthorpe271]
PJST Offline
Loc: Rainham, Essex
I had a squeak but got a letter saying that there was a potential clutch problem and they were recalling certain models to fix it. Mine went in, the mechanic took it way and it came back "fixed" and the squeak has gone!!!
#105912 - 08/10/07 10:09 PM Re: Squeaky Clutch Pedal [Re: PJST]
There was an issue where some Fiestas (and Fusions) had to be recalled due to a clutch problem, whereby they had to add a washer to the clutch pedal, see this thread here:
http://www.fordfiestast.co.uk/showflat.php?Cat=0&Number=73083&an=0&page=0#73083
As far as I was aware though, that was a separate fault to the squeaky clutch.
#105913 - 09/10/07 07:22 AM Re: Squeaky Clutch Pedal [Re: JamesUK]
Sir Mr Fabrix Offline
Loc: Rixton,Cheshire
Lol thats it! ig ot that problem but some days it goes away some days its there great decription.
Current Car: Volkswagen Golf R Mk 7 | 19 inch Pretorias | Sat Nav | Dynamic Drive Chassis | ECU Upgrade to come!
Previous Cars:Ford Focus ST2 CP320 & Ford Fiesta ST150
Car to come: Ford Mustang 5.0-litre V8 coupe in Oxford White
#105914 - 09/10/07 11:37 AM Re: Squeaky Clutch Pedal [Re: Sir Mr Fabrix]
Fordie Offline
Loc: Cumbria
my clutch sqeuaks all the time, i think ive got used to it and then its of again! when ive got passengers in, i'm like: "can you not hear that?" and they are like "no, what ar you going on about" i'm starting to think its all in my head but it drives me nuts, but i keep forgetting to do anything about it!
I hate BMW's *I AM THE STIG*
#105915 - 09/10/07 12:54 PM Re: Squeaky Clutch Pedal [Re: ChrisCumbria]
PJST Offline
Loc: Rainham, Essex
There was an issue where some Fiestas (and Fusions) had to be recalled due to a clutch problem, whereby they had to add a washer to the clutch pedal... As far as I was aware though, that was a separate fault to the squeaky clutch.
Totally true. The mechanic that did the clutch recall on mine added the washer I needed and also said he "gave the clutch a once over" for me. I'm guessing he noticed the squeak and sprayed it with something??? I dunno what he did but whatever it was it worked
0 registered (), 1421 Guests and 0 Spiders online.
