#265762 - 17/12/10 03:09 PM cleaning throttle body *****
db04dan Offline
i might clean my throttle body as i have 4 weeks off from uni.
but i cant find the post which told you step by step and cleaning products used ect.
any help on where this is?
if not what do you need to do and what products are best to use.
plus pics would be a great help
#265763 - 17/12/10 03:12 PM Re: cleaning throttle body [Re: db04dan]
Not WD40..................................!!
#265764 - 17/12/10 06:01 PM Re: cleaning throttle body [Re: ROB IS THE STIG]
Duff Offline
Loc: Flanders, Belgium
Not that hard mate, don't worry
Take of your air filter first...
Then you'll see this... but probably black on the inside as this is a brand new one
Just use carb cleaner or brake cleaner and clean the inside, i've heard some people say you shouldn't be moving the throttle valve (dunno if that's the word) but i did that and didn't experience any problems after.
#265765 - 17/12/10 07:08 PM Re: cleaning throttle body [Re: Duff]
its a butterfly valve i think and if you take the TB off, you can move it with the lever (shaft arm or whatever it is) but i dont think you should be touching the butterfly.
#265766 - 17/12/10 08:55 PM Re: cleaning throttle body [Re: H47PER]
Also if you remove it you can clean the other side, and wont have to move the butterfly as much
#265767 - 17/12/10 10:24 PM Re: cleaning throttle body [Re: Alex_H]
lukamon Offline
Loc: norfolk
petrol, toothbrush, and some paper towels to clean up are all you need.
(by the way, that wire clip on the throttle is NOT stuck, its just a bastard)
#265768 - 17/12/10 10:28 PM Re: cleaning throttle body [Re: lukamon]
You flick up the red bit with a screwdriver first
#265769 - 19/12/10 02:49 AM Re: cleaning throttle body [Re: Alex_H]
lukamon Offline
Loc: norfolk
ahh yeah thats it, i havnt got mine anymore so cant go look
#265770 - 03/03/13 05:10 PM Re: cleaning throttle body [Re: lukamon]
Hoff Offline
Loc: Sheffield
Just did mine after reading a few threads on here. Piece of cake! Only took me half an hour and made a huge difference to the idle.
Thanks for all the help guys!
2016 ST180 - Performance Blue
Mountune MP215 | Airtech Short Shifter | ITG CAIS |
Heko Wind Deflectors | EBC Pads and Discs |
#265771 - 03/03/13 05:30 PM Re: cleaning throttle body [Re: Hoff]
Really is simple and makes a real difference
#265772 - 03/03/13 06:33 PM Re: cleaning throttle body [Re: ROB IS THE STIG]
Finalreminder Offline
Loc: Chester
Carb cleaner is better I've found. I cleaned my Vectra Diesel and V6 Vec with that stuff on two truly caked up TB's, and they came up nice. Then finished off with some Autosol or T-Cut.
No harm comes from touching the butterfly.
#265773 - 04/03/13 09:26 PM Re: cleaning throttle body [Re: Finalreminder]
enforcer Offline
oooo think i need to do this when i clean my KN
#265774 - 04/03/13 09:45 PM Re: cleaning throttle body [Re: enforcer]
Worth it even if it just a tiny bit sooted up
#265775 - 04/03/13 10:02 PM Re: cleaning throttle body [Re: Jack_P]
Hoff Offline
Loc: Sheffield
Now that I've had a bit more time in the car since cleaning the TB, I can't believe the difference. It picks up from stationary at low revs SO much more smoothly than before. I never would have thought the difference would be so noticeable, just from a clean!
After seeing the change after just a clean, I'm now on the hunt for a 60mm TB!
#559448 - 13/03/16 04:52 PM Re: cleaning throttle body [Re: db04dan]
Dk-st Offline
hey all - bit of a noob to the site but here goes. I recently fitted sports cat to milltek full system and 4-1 manifold and it was running mint popping and crackling when letting off but since I had my throttle body off for a clean its stopped popping,,, it seemed to go through some kind of reset after the t/b clean revs everywhere but then settled after a few km's funs fine but no pops any ideas????
typhoon k&n
milltek 4/1 manifold
full milltek non res inc sports cat
big brake upgrade
ap coilovers
#559455 - 13/03/16 07:03 PM Re: cleaning throttle body [Re: db04dan]
probably because you now have slightly better cleaner airflow and not as rich running anymore.
#559460 - 14/03/16 12:17 AM Re: cleaning throttle body [Re: db04dan]
The ECU has probably learnt a more corrected air fuel ratio.
#559650 - 29/03/16 05:28 AM Re: cleaning throttle body [Re: db04dan]
Dk-st Offline
thanks good to know
typhoon k&n
big brake upgrade
ap coilovers
0 registered (), 1006 Guests and 0 Spiders online.
