#359866 - 19/10/11 12:54 PM
Re: Engine warning lights. MOT
[Re: Kev]
From MOT from December 2011, the below changes will come into force, which will be very bad news for some.
HID lights – Specifically those aftermarket kits that give the very bright headlight beams. Any cars found with these kits will be an automatic MOT failure. Testers are able to easily spot the difference between HID kits, and manufacturer fitted Xenon’s. Easy to spot as Xenon cars have suspension level sensors, in car beam adjuster, and usually headlight washers. Chipped ECU’s - Unsure of just how/if this one will realistically be enforced, but any cars with chipped ECU’s will in theory be an MOT failure. I can only assume VOSA have found an easy way of checking ECU software through the cars OBD port (diagnostic plug). Wiring harness – The general condition of he wiring harness will be checked to make sure there is no rubbing or chaffing, and that the harnesses are in generally good condition. If unsecure, or damaged again MOT failure. Airbag warning lights - If any warning lights are illuminated, it will again be an MOT failure. This is all the info i can find.
#359868 - 19/10/11 05:22 PM
[Re: STASON]
It's currently okay to have any light bar the ABS on.
VOSA are curently thinking of changing it to all lights, but this is very unlikely.
K&N, 35mm droper, axle spacers, de-tango,
LED's all round, Retro Fiesta badge, wind deflectors.
#359871 - 19/10/11 08:15 PM
[Re: alan_t_st]
Loc: Bourne, Lincs.
i'd imagine its to do with the extra emmissions the cars will be giving out, i assume giving cars more power by a remap will also increase emmissions.
Still a joke, we'd all go back to illegal MoT's
#359873 - 19/10/11 08:53 PM
[Re: redstLee]
Loc: Bourne, Lincs.
If I remember correctly the remap/chip thing was on the cards last year aswel but never happened so carnt see it this year either
flippers need to stop trying then!
#359874 - 19/10/11 08:55 PM
[Re: redstLee]
Chipped ECU’s - Unsure of just how/if this one will realistically be enforced, but any cars with chipped ECU’s will in theory be an MOT failure. I can only assume VOSA have found an easy way of checking ECU software through the cars OBD port (diagnostic plug). good luck getting your MK1 RS's through an MOT then ford chipped the standard 2L zetec ECU i believe to make it run with the turbo and tune it up... the HID thing has been said to come in since the HID lights were 1st fitted to cars back in the early 2000's and nothing yet... and my car last year had its MIL light on and it went straight through on emissions, he said as long as it gives out the right emissions it doesn't matter
#359878 - 20/10/11 05:04 PM
[Re: STASON]
i think standard Kenny your RS has a chipped ECU
#359879 - 20/10/11 06:55 PM
[Re: Dan_The_Man]
#359882 - 24/10/11 08:52 PM
[Re: ST_Lee]
mountune are allowed to use the ford software to map the ECU
they dont chip it they reflash it for the 165 and 185 but the MR200 is chipped
#359883 - 24/10/11 09:06 PM
[Re: Dan_The_Man]
what's the difference
1512
