#369579 - 22/11/11 04:47 PM
Re: Dodgy AUX Connection
[Re: DaleZKO]
Loc: Lancashire
I had the EXACT same problem....no need to replace anything. See my old thread: http://www.fordfiestast.co.uk/showflat.p...&PHPSESSID= What I had to do to fix it was take of the gear knob and then the gaiter so I had access to the insides of the centre console thingy. If you look inside to where the AUX socket is located you'll see the wire coming down and chances are it is rubbing/catching on the gear cables. Get some good sticky tape and tape it to the roof of the console...basically so that it doesn't touch the gear cable/lever. And before you put the gear gaiter and knob back on, just test it to make sure its working and make sure you change gears with it on so you can be sure it isn't catching any more. This whole thing sounds a bit tricky perhaps but it is super easy. I did it and I had no prior experience with anything like this. The gear knob screws right off and the gaiter pulls right off. If you know how to get the centre console thing off you could even do that but I couldn't figure it out...didn't need to in the end though. Let me know how you get on
Performance Blue 07 ST (Naked). Full leather heated seats, electric folding/heated mirrors, factory fitted privacy glass, bluetooth, voice control, mp3 connectivity, auto wipers & lights, rear parking sensors.
Eibach lowered 35mm
Mountune MP165
#369581 - 22/11/11 06:39 PM
[Re: DaleZKO]
replace your ipod cable with a gold plated one. That's all needed.
#369583 - 22/11/11 08:38 PM
[Re: DaleZKO]
Gold plated are fraction thicker and fit the AUX so much better, only try gold plated ones.
#369584 - 22/11/11 09:49 PM
[Re: YellowBadge]
Loc: Lancashire
Pretty sure its the exact same problem as mine due to the connection going funny when changing gears, and not due to the cable betweem mp3/ipod and AUX socket. The Aux cable from the head unit/stereo runs down from the back of the stereo and hangs from the front passenger side of the centre console. It then goes over the gear cable into the AUX socket which is on the drivers side...this was what mine was like anyway. It had just dropped down a bit and the gear cable was pulling and pushing it about, making it go all funny exactly as you have described Dale. Would be all left speaker and super quiet one minute, change gear and suddenly its blasting out of both, change gear, goes funny again etc etc.
As for ripping the rubber gear gaitor off...no need to be so violent :P It clips into place and just requires a little tug to get it out (the whole plastic ring base comes off with it). Once you're done it fits back into place nicely and the gear knob screws back on.
Eibach lowered 35mm
Mountune MP165
#369588 - 24/11/11 02:48 PM
[Re: DaleZKO]
Loc: Lancashire
#369593 - 24/11/11 09:22 PM
[Re: DaleZKO]
Best Non ST Car of the Year 2013/2014
standard are good enough if you update the headunit if you don't wanna update the headunit, update the speakers. or just blow your cash and do both like me
2015 Chevrolet Camaro ZL1
#369594 - 24/11/11 10:25 PM
[Re: steviehouse]
Loc: Lancashire
ah well I've got the ford 6006 cd changer head unit...must not be up to par with the sony unit then. It's not awful...but I've heard better.
Eibach lowered 35mm
Mountune MP165
