#504239 - 17/04/13 07:28 PM Abs light
redstLee Offline
Hey guess wonder if anybody can help with a mechanical mind
I have been flushing out my pas fluid and fitting another cooler got it all sort while it was up on axel stands turned it over and went from lock to lock to bleed the system and then abs light came on and don't know why.
Anybody got any ideas
#504240 - 18/04/13 05:48 AM Re: Abs light [Re: redstLee]
gary4vicky Offline
no idea mate sounds a bit strange
Poppy:
Tinted third brake light
DMB Badges
Mountune pas cooler
Painted Calippers
hose covers
MR200
Mountune billet arm
Front Strut Brace
35mm eibachs
Mountune big brake kit
#504241 - 18/04/13 06:04 AM Re: Abs light [Re: gary4vicky]
kinobeSTew Offline
Loc: Hindley, Lancashire, England
Did you do it with the engine running?
Maybe you knocked something a little bit when putting your wheel back on the other day? Unlikely though.
<center>
Click signature to see my Lil Red ST project blog</center>
#504242 - 18/04/13 07:12 AM Re: Abs light [Re: kinobeSTew]
dontpannic Offline
Have you driven it since? If both front wheels were off the floor they'd be spinning and the system will recognise there's a discrepancy between the speed sensors in the front and back wheels, and assumes that theres a fault on a speed sensor.
Put it back down on the ground, drive it and brake - the light should go off.
Happens all the time on 2WD rolling roads too.
#504243 - 18/04/13 11:28 AM Re: Abs light [Re: dontpannic]
redstLee Offline
Ah thanks nick will try tonight when I'm in from work
#504244 - 18/04/13 04:38 PM Re: Abs light [Re: kinobeSTew]
he would have been wearing it if he had the engine on while changing pass
#504245 - 18/04/13 05:24 PM Re: Abs light [Re: dontpannic]
I did this once, got in a bit of a panic and the guy goes " Its only because the front wheels are running and the rears aren't, you're supposed to be a hnc students aren't you???"
Havent forgot since
#504246 - 18/04/13 08:48 PM Re: Abs light [Re: Dan_The_Man]
kinobeSTew Offline
How so? I know it pumps fast, but not sure how fast because i've always had a helper on hand to turn the steering whee.
It turns out that he did actually have the engine running, I asked him earlier
<center>
#504247 - 18/04/13 10:13 PM Re: Abs light [Re: kinobeSTew]
redstLee Offline
Right the and is sorted now for another question has anybody disconnected the battery over nigh/24hours did this last night took the car out to night and its had a few fits where loss of power dials drop and a red light comes on at the top of the clocks in the centre
#504248 - 19/04/13 07:00 AM Re: Abs light [Re: redstLee]
dontpannic Offline
Not had that one... I've had the engine with a rough idle when connecting the battery back on but that's only while the ECU re-learns the mixture settings.
#504249 - 19/04/13 10:35 AM Re: Abs light [Re: kinobeSTew]
Milky Offline
Loc: Sheffield
Extremely fast, with the pipes off it will empty in less than a second of the engine being on.
#504250 - 19/04/13 11:17 AM Re: Abs light [Re: Milky]
dontpannic Offline
And with force. When I attempted a solo PAS fluid change without a helper the wine bottle I was using to catch the fluid was knocked clean off of the slam panel by the force, and I had squirted power steering fluid at least 15ft down the drive and across the road.
#504251 - 19/04/13 01:13 PM Re: Abs light [Re: dontpannic]
redstLee Offline
Well this has now got a whole lot worse
First I get this every dial apart from speedo drops
But now this
Message display says
Check owners manual
Engine fault
High engine temperature
#504252 - 19/04/13 01:15 PM Re: Abs light [Re: redstLee]
dontpannic Offline
Didn't knock the throttle body did you? Make sure that's connected properly.
Does the transmission light flash at all?
Sorry... high engine temperature? Sounds like a dodgy sensor or an airlock?
Edited by dontpannic (19/04/13 01:16 PM)
#504253 - 19/04/13 07:31 PM Re: Abs light [Re: dontpannic]
Josh92 Offline
Loc: Oxford, England
Is the maf sensor plugged in as it can cause cars to go in restricted performance
#504254 - 19/04/13 09:31 PM Re: Abs light [Re: Josh92]
Mine does that after trackdays normally on the way home when just crusing along, I turn it off on again and never see it again
#504255 - 20/04/13 07:41 AM Re: Abs light [Re: Dan_The_Man]
redstLee Offline
Right it's all sorted dirty connection on the negative for the battery the guy only found it by chance aswell
#504256 - 20/04/13 10:12 AM Re: Abs light [Re: redstLee]
gary4vicky Offline
Glad its sorted mate. Are you still coming down in your car?
Poppy:
DMB Badges
Mountune pas cooler
Painted Calippers
hose covers
MR200
Mountune billet arm
Front Strut Brace
35mm eibachs
#504257 - 21/04/13 04:27 PM Re: Abs light [Re: gary4vicky]
redstLee Offline
Yes I did Gary, you may have seen it
#504258 - 21/04/13 05:34 PM Re: Abs light [Re: redstLee]
gary4vicky Offline
I thought I noticed it today when we may or may not removed stuff from your boot
Poppy:
DMB Badges
Mountune pas cooler
Painted Calippers
hose covers
MR200
Mountune billet arm
Front Strut Brace
35mm eibachs
0 registered (), 980 Guests and 0 Spiders online.
