#547484 - 15/10/14 08:23 PM
Re: 02 Sensor Cheat
[Re: Tobi]
Loc: Norfolk
Get a remap and turn it off!
2005 Fiesta ST 2012 Honda CBR1000RR Fireblade 2002 Toyota Celica
#547489 - 16/10/14 05:49 AM
Re: 02 Sensor Cheat
[Re: kenny]
It's a 50 50 mate but the cheapist so start with that Sorry mate I was referring to the use of a scanning tool to reset the ecu to turn it off... But yeah I hear these things (elbows) are hit and miss and might be the difference between me getting a system or not as really cant be bothered with the hassles of forking out for a tune etc
#547490 - 16/10/14 06:54 AM
Re: 02 Sensor Cheat
[Re: Tobi]
Sorry mate I was referring to the use of a scanning tool to reset the ecu to turn it off... When you erase the fault codes it turns the light off. If the light comes back on then the fault has re-occurred. IF you install an elbow, and IF you reset the codes, and IF the elbow does what it should, then the light will stay off. If the light comes back on, then the elbow hasn't worked. My light is on all the time, I just ignore it now, and check the codes occasionally to make sure nothing else has gone wrong lol
Edited by dontpannic (16/10/14 06:55 AM)
#547504 - 17/10/14 01:52 AM
Re: 02 Sensor Cheat
[Re: dontpannic]
Sorry mate I was referring to the use of a scanning tool to reset the ecu to turn it off... When you erase the fault codes it turns the light off. If the light comes back on then the fault has re-occurred. IF you install an elbow, and IF you reset the codes, and IF the elbow does what it should, then the light will stay off. If the light comes back on, then the elbow hasn't worked. My light is on all the time, I just ignore it now, and check the codes occasionally to make sure nothing else has gone wrong lol Thanks guys... Do you have any kind of cheat on your system which isn't working? Or are you just running without? I hear there are specific ways to install them interns of angles and the way which the sensor sits after installing to ensure it works as it should. Weird it's hit and miss, it surely should either work or not... Does the CEL put the car into any kind of limp mode?
#550263 - 02/01/15 11:44 AM
Re: 02 Sensor Cheat
[Re: Tobi]
FYI This works... Going on 3 MOnths, and my CEL hasn't shown yet
980
