#50995 - 25/07/06 04:40 PM
My tyres again
Loc: Cumbria
ok for those of you who wanted pictures here they are. for some reason they dont look as bad in fotos, but close up they do! pic 1 & 2. see the right hand side of the tyres to see how much its worn compared to the left and pic 3 i tried to show the wear again, it is on the marker on the right hand side, but plenty of wear on the left. ignore the yellow pen, i wanted them marked so that they wernt thrown out at the garage as scrap, as i wanted them for evidence if it happens again!!
Edited by ChrisCumbria (30/07/06 01:29 PM)
I hate BMW's
*I AM THE STIG*
#50996 - 25/07/06 05:25 PM
Re: My tyres again
[Re: Fordie]
christ! is ur tracking ok? or ru a nutter on the road?
#50997 - 25/07/06 08:00 PM
Re: My tyres again
[Re: ROB IS THE STIG]
The camber is out of alignment
#51001 - 25/07/06 10:34 PM
Re: My tyres again
[Re: Fordie]
Loc: West Midlands
I think that on the st you can make adjustments on the rear track/camber
A Thing Of Beauty Is A Joy Forever
#51003 - 26/07/06 08:33 AM
Re: My tyres again
[Re: Fordie]
Find a place with a four wheel geometry test then send the evidence to Ford.
The only thing is they will say it could have been knocked out by road damage. Even though it would have taken a hefty whack to put it out of alignment.
If the alignment is all ok a mis-torqued wheel nut could cause uneven tyre wear.
#51007 - 26/07/06 02:43 PM
Re: My tyres again
[Re: Fordie]
ok so i go to the garage and say the camber is out of alignment and they will laugh at me cos i'm a girl
File a lawsuit for sexual harrasment. I bet that would make them take you seriously!
#51010 - 27/07/06 06:51 PM
Re: My tyres again
[Re: Fordie]
my dad comes with me. he knows whats what. except they start talking tat to him too and them we both get mad when they wont listen
fight!! fight!! fight!!
#51012 - 27/07/06 10:35 PM
Re: My tyres again
[Re: neila]
if its worn on the inner edge it's running to much negative camber if it'sworn on the outer it's running to much positive camber.has it had a bump?is the stub axle bent slightly,this would cause the tyres to wear.
Gentlemen please read the thread... A bump would change the camber and wear one wheel. Amanda's tires are BOTH worn on the inside - unless she had the exact same bump force on both sides - which is very unlikely - I don't see how this could have happened.
If I were you Amanda I'd write a complaint letter to Pirelli customer service with proof that you've had your car checked over for alignment and all possible other things, then wait for them to answer. You never know you might just have landed on a bad batch of tires in which case you may get some of your money back.
#51013 - 27/07/06 11:01 PM
Re: My tyres again
[Re: Nick02]
Loc: West Midlands
i know its a long shot but i read somewere that tyres are sided and have a directional arrow on the tyre,maybe they were fitted incorrectly,just a thought !!!
#51018 - 30/07/06 10:12 PM
Re: My tyres again
[Re: Red_St]
What use will sending a letter or pics to Pirelli make? Surely all they'll say is the tyre wears according to the way the car is set up (correctly or incorrectly)?
#51020 - 31/07/06 02:31 PM
Re: My tyres again
[Re: Nick02]
Ahhhh yes I never really thought of that!
#51027 - 03/11/06 06:29 PM
Re: My tyres again
[Re: Fordie]
know its an old thread, but didnt seem like you get a fix? It not the tyres fault though for definate, so you will see the problem again in 10k
did they check the camber? that looks like camber wear not toe, thoough since its a torsion bar rear you shouldnt really get camber wear? It should ahve some negative camber, but not enough to do that, even -2 with toe would take a while to kill em.
if its help these are fords specs, ask to see measurements against all of these, unless they can do so they havent checked it all properly. Keep on at em as its 100% a mechanical issue with your car!
front toe: +00.09 (tolerance +00.04 to +00.14) front camber: -00.44 (-02.07 to +00.39) caster: +03.25 (+02.18 to +04.32) rear toe: +00.16 (+00.05 to +00.25) rear camber: -01.02(-02.18 to +00.13)
16" rims front toe +1.1mm (tolerance +0.5mm to +1.6mm) rear toe +1.8mm (+0.7mm to +3.0mm)
17" rims front toe +1.1mm (+0.5mm to +1.7mm) rear toe +2.0mm (+0.8mm to 3.2mm)
#51028 - 03/11/06 07:43 PM
Re: My tyres again
[Re: eddyesi]
eddiesi, thanks for these values, they are most interesting. I assume the first set of values is in degrees right? But what makes me laugh is the tolerances they give! Quote:
They don't half cover their ar55es with such big tolerances... No wonder Amanda's car comes back with an "everything is fine" message, even if it has a negative camber at 2 degrees (-2) it's within the bloomin' tolerances but it does not take a scientist to even predict it will wear tires on the inside! It's ridiculous for heaven's sake!
RS team goes to great lengths refining the handling of this car and then someone at Ford gives the green light to publish camber and toe-in tolerances for the rear (let alone for the front) that actually allow differences on BOTH sides of 0! No wonder that different people are having very different handling experiences with their cars. Now I understand why some people say their ST is very tail happy...
I think that with these values eddiesi has hit the nail on the head. I'd ask to see the actual measured values on the car and compare them against these - look no further!
1421
