#331920 - 11/07/11 08:00 PM
Dangerously high engine temps?
Got stuck in the smash at J27 on the M6 today, was stuck in horrible heat for about 30 minutes watching my engine temp rise to maximum triggering an engine warning light. Thankfully the people behind and three lanes across had left a massive gap, big enough for me to reverse a bit cross the lanes onto the hard shoulder and drive about 500 yards to Charnock Richard services. The engine temp went down but as soon as I started the car it shot back up triggering the warning again. After sitting for a further 20 minutes I decided to join the M6 again in the hope that gaining some momentum would help cool the engine, it did. After trawling a couple of miles at 10mph with the temp needle hovering just below maximum the traffic petered out and I managed to get up to 70 and bang the tempt dropped right back down to normal.
I've never had this before and not sure if it's just down to it being a hot day and sitting in traffic not helping or if it's done serious damage and to get it checked?
Nathan Smith | Web Developer
#331923 - 11/07/11 08:13 PM
Re: Dangerously high engine temps?
[Re: Davest]
Is the fan working? Check the water coolant level
#331927 - 11/07/11 08:36 PM
[Re: Alex_H]
It wasn't that hot today surely.............. sounds odd mate coz once the temp rises to a particular point the fan should be on doing the cooling that driving would normally do. Get it looked at
#331928 - 11/07/11 08:38 PM
[Re: ROB IS THE STIG]
25degrees today
#331929 - 11/07/11 08:40 PM
Exactly, not quite the Sahara.............
#331932 - 11/07/11 11:13 PM
[Re: Kev]
Also if your ever in doubt and need to cool the engine, put your windows down and put the heating on max temp and max blow (4). It may be Uncomfy but takes the edge of the engine temp and saves it from cooking itself.
#331936 - 12/07/11 04:00 PM
[Re: Smith57]
Don't burn your face off...
#331938 - 12/07/11 06:30 PM
Just checked the pipe from the coolant to the radiator and seemed the same temp across? Not too sure about spurting hot water from the coolant tank so I'll get the car to the garage on the weekend for a once over.
#331940 - 25/07/11 02:17 PM
[Re: WiggzST]
Had it checked over at Evans Halshaw today, apparently the engine fans weren't plugged in! No idea how that's happened. Other bad news includes rear disks are all but gone, front tyres are fubar (after less than 6000 miles which I find strange) and a rear wheel bearing is on it's way out.
#331945 - 25/07/11 02:35 PM
[Re: Smith57]
thats why i never go to fords any more even with my new cars id just go to a ford approved garage
True, I try and avoid them, normally goes to my aunties garage but she couldn't get it in for a while and I thought with the engine temps going sky high it needed checking ASAP. Today was the earliest I could get it in Fords.
i would of done the same mate if i couldnt off got it in the one i go to
#331950 - 25/07/11 05:18 PM
[Re: Smith57]
dont let ford do a bearing! they are £40 max for parts, if you jack the car up and try to wobble the wheel and its loose then yes its going if your wheel is solid and doesnt rock its totally fine. and my mates st did 15K on pirellis from new! they never wear out! i cant believe they would go so quick they are solid rubber
#331954 - 25/07/11 08:40 PM
[Re: WiggzST]
Local garage charged me 25 for a rear bearing when they was inspecting the rear brake shoes (apparently) dont know on labour but i would rather let a garage do a bearing then me as you need a press...
#331956 - 26/07/11 06:14 PM
[Re: Alex_H]
Damn Fords!
With regard to breaks, I got EBC OEM standard breaks on my old and they where much cheaper than the ford ones, seemed ok but where only on my car about 7 months then my car was written off so cant comment on how long they last
Brakes
i heard after getting wet the EBC discs tend to rust up really quickly, compared to OEM, im sure this must have an impact on disc health and the state of your brake pads
1694
